My Hoe
Platinum Member
- Joined
- Oct 31, 2010
- Messages
- 562
- Location
- NYS--Various Parts
- Tractor
- Kubota B3000HSDCC, BH77, 5' Belly Mower, 6' Hyd. Angle Plow
Hi all,
Due to back/foot problems, I have to limit both my time on small, riding mowers (rough ride quality) and time holding up heavier string trimmers.
Plus, our new (to us) property has lots of gently-sloping hills/apron areas (think, around the entrances to the barn/outbuildings, etc...) that would be perfect for a powered, walk behind mower, but too steep for a B-sized Kubota (which I want for other purposes).
And the walk behind mower won't solve the large amount of string trimming required.
So...never having seen one in action, does the DR String Trimmer actually let you do the type of "fine trimming" needed, around the bases of buildings?
Can it also serve as a small lawnmower, on these apron areas, eliminating the need for the use of a weed-whacker AND a walk-behind mower?
Due to the hills, I would want power-on-the-wheels.
Can anyone recommend a specific DR model?
Is there a brand OTHER THAN DR, which anyone can recommend?
My neighbor's Sears trimmer came with an (optional--$23.?) wheel kit, which allows you, in theory, to NOT hold up the weight of the trimmer-end of the whacker--it's running on wheels, and you just hold up the powerhead end.
The problem is: these wheels were the size of roller skate wheels--IMO, too small. They had too much rolling resistance, over a normal (bumpy) lawn.
I picked up a used (wheel-driven) seed broadcaster, with very lightweight, pneumatic (8"?) tires on plastic wheels, with the idea of converting it to a "wheel kit" for a conventional weed whacker. Why? Because those big, light, air-filled tires simply BOUND over a bumpy lawn, near-effortlessly, whereas my neighbor's 2" tall wheel kit made his trimmer push hard and get stuck a lot.
Has anyone seen a wheel kit for a weed whacker that uses the big (8"?), pneumatic tires I'm describing?
Thanks all, for entertaining my barrage of questions.
My Hoe
My Hoe
