Best way to smooth a lawn
   / Best way to smooth a lawn #1
Jules083
Long story short this spring I'm going to have about an acre of lawn that will need smoothed, seeded, and strawed. This is a farm, not a neighborhood, so my goal is to just get it good enough to be able to mow quickly without bouncing out of the seat and to not scalp half of the yard with my 72" deck.
That acre is going to be graded by a friend with his dozer, then it's up to me to get it ready to plant. There's also about another 3 or 4 acres I mow that I would like to get better, I currently have a 'pattern' I have to follow to avoid scalping. That ground was previously cut with a brush hog monthly, I started using a mower a few summers ago when I got a bigger mower.
I have a 32 horsepower 4wd compact tractor, a 70 hp 4wd John Deere with a front end loader, and a Farmall M at my disposal. I'm thinking that a box blade might be the best way to do it, but I don't know. I've never ran one, just watched some youtube videos.
The small tractor is a John Deere 2720, and is about 4 1/2' wide. The larger one is almost 7' wide. If I decided to go with a box blade I'm not sure what tractor I would plan to pull it with. The small one, obviously, is much lighter and more maneuverable. The big one pulls a lot harder, but is heavy and not as maneuverable. I won't be rushed for time at all, but I don't want to **** around all month and beat the **** out of the small tractor trying do the job. I would think that the small one will do a better job, assuming that it can actually do the job.
The areas that are already seeded but rough I'll probably dump a few buckets of dirt around then just drag it around a bit. The unseeded area will need a lot of attention, I'm guessing just keep running over it until it's right. I'm planning on using the blade after I'm finished to touch up the driveway, probably run through it every spring or something. There are a lot of hills and high spots here, smaller equipment would be an advantage.
What do you think? Big box blade, small one, or something else? Thanks.
   / Best way to smooth a lawn #2
What's your budget?
If it's under $1K, then go with the box blade. It's a general purpose implement that you can use for a variety of jobs. If you've never used a BB before, plan on at least a few hours time to get the hang of it.
If the budget is several $K, then there are implements that are dedicated to landscaping work. Google "lawn renovators".
   / Best way to smooth a lawn #3
I would use a landplane to smooth the lawn areas, much easier to use than a boxblade especially for newbies. I would prefer a larger 7 or 8' model to use behind the 70hp Deere. Something like the LP1196 comes to mind or some of the other brands with built in rippers such as the Landpride models.
Heres a link to the Frontier landplanes,http://www.deere.com/en_US/docs/non_current/dsfe41828_land_planel_lp10_11_lit.pdf
What's your budget?
If the budget is several , then there are implements that are dedicated to landscaping work. Google "lawn renovators".
Under 1K for sure. Any more than that it would probably be cheaper for me to just pay someone to do it.
Will a 2720 handle the job do you think? This little tractor continues to amaze me, but its still just an oversized lawnmower when you really think about it.
   / Best way to smooth a lawn #5
I would go over it with the box blade on the small tractor,then find something long and heavy to drag behind the tractor or box blade. With the short wheel base on tractors it is hard to get things level,but if you get it reasonably smooth then drag it ;the drag takes off the small humps.:thumbsup:
Never thought of those. Seems like they would work better in soft stuff, but not at all if the ground is hard. From the looks I could probably build one with some angle iron and just drag it around with my 4-wheeler.
I'm pretty used to running equipment, although I am a newbie to box blades. I started running the plow and disks around age 10, bailer around 12 or 13, and combining by 14 or so. Basically as soon as I was heavy enough to run the brakes I was running that tractor. My uncles had it easy after a while, I wouldn't let them run anything. :laughing:
Maybe I'm over thinking this, and can do this a lot easier and cheaper than I originally thought. Disk the whole yard until it's soft dirt. Wrap a chain around something heavy, and drive around until I'm satisfied. I have a friend of a friend that runs a scrap yard, all I'd have to do is borrow a piece of I beam or something from him.
   / Best way to smooth a lawn #8
Look at this current thread,
http://www.tractorbynet.com/forums/...233010-just-another-first-tractor-thread.html
You can get good results with a drag of sorts but you can get better results with a landplane. Above is another current thread where a member is considering a 2720 with the same work in mind. Page three I have posted some pics of my own landplane I built in 2009 and the results using it.
   / Best way to smooth a lawn #9
You'll be disappointed with a box blade attempting the work you need to do.
Hire someone to disk it and then drag with a well designed drag. A single I beam might work if you pull it on the bias but there are better designs.
All I have to do is hook to my disk....
I have a drag that I've used in the fields. I think it might be too much for a lawn but it wouldn't hurt to try. It's concrete, maybe 1' thick, 3' long, 8' wide. It's big to be dragging around a yard, but might be worth a shot. I was thinking that a box blade would do a better job, but maybe not. Maybe disk, drag, then run the snow plow around on it.
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2022 THOMPSON PUMP 6X6S1 PORTABLE PUMP (A59823)
2022 THOMPSON PUMP...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
