etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,054
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
On my Yanmar YM2310 is a Bulldog 285 FEL. The cylinders that roll the bucket are too long. Actually, the rods are too long. The bucket will not roll back as far as the Bulldog specs show. When fully retracted the rods stick out about 3 inches farther from the cylinder than they should. There is about 3 inches of exposed rod. I have never seen this before. Just to check I disconnected the rods from the bucket and they will still not go in any further. Plus, when the rods are disconnected the bucket can be rolled back by hand to where the Bulldog spec sheet says it should.
I can see two ways to shorten the rods. I can take the ends off of the cylinders, pull the rods out, unscrew them from the piston, shorten and re-thread the rods, and then re-assemble. I don't really care for this option because the cylinders don't leak now and I don't know if I can get new seals if I damage any.
The second option is to extend the rod all the way out of the cylinder, cut the end off, shorten the rod, and then weld the end back on.
I have the equipment and skill to do either option.
Opinions? Other options?
Thanks,
Eric
Thanks,
Eric
