Best way to install livestock fence over a terrace?
   / Best way to install livestock fence over a terrace? #1
ohmyback
Bronze Member
Missouri
JD 750 GC1705
Hello,
I am wanting to install some livestock fence on my small property. I was wanting to use
goat fence and I need to go over a terrace a couple of different times. What is the best
way to go up and over and keep the fence tight?
   / Best way to install livestock fence over a terrace? #2
Without a picture - this is the way I install barbed wire. Up to - across - down the far side. You must have strong points on the top of the terrace. On the near side and the far side. Stretch the fencing to one strong point and tie off. Do the exact same on the other side. Then stretch across the terrace and tie off at each strong point. Posts installed at appropriate intervals.
My "strong points" are either rock gabions or 2 1/2 inch heavy wall pipe. I use pipe when I can bore a hole in the bedrock and lock in the pipe with a two part epoxy gel concrete. Otherwise I use a rock gabion.
My rock gabions are made with heavy gauge hog wire. A four foot diameter circle of wire - four feet high. Set on the ground and filled with rock. Unfortunately - the picture of one I have - used as a corner anchor - has been deleted from my file.
   / Best way to install livestock fence over a terrace? #3
Goats...fences... Isn't there an old Texas saying about goat fencing that "it ain't tight enough if smoke blows through it"? :)
Our fencing (not for goats!) has lots of elevation changes like terraces. I think that the challenge is the inside corner, where the uphill fence and the horizontal fence will be trying to pull the inside fence post up and out. I would suggest that the inside corner, close to the hill, should have at least a corner style "H" braced double posts to handle the fence stress. If your terrace isn't large, I would brace the post uphill to the inside post as well, giving you all three posts being fastened together to resist the fence strain. For all of them, I would put in the deepest post that I could get away with. For goat fencing, you would usually need to cut the fence into an uphill piece, a terrace piece, and a downhill piece, and stretch each of them individually.
We have used two 2" pipe driven in 3-5', crossing just above ground level and a wire tying the two together running up the fence to provide an anchor to apply down force on a barbed wire fence at the inside corner. I doubt that would work for you. If I were doing it again, I would use three pieces of steel fence posts, welded together.
FWIW: We also run electric fence inside to keep animals from pressuring or exploring the main fence.
Having grown up with hillsides with relatively slow change of slope, I find these rapid change of slope fences a lot more work, because you need so many control structures to get the forces right on the fence. If we had more rock, I would consider @oosik's suggestion of gabions, but for goats I would put the gabion outside their enclosure.
All the best,
Peter
Thank you for the explanations. Sections it is , oh boy that does create a lot of extra work. Maybe I should rethink this :) .
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Black Plastic Mailbox and Post Kit (A54865)
Black Plastic...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
