Just bought a used Woods RD7200. The gear oil is milky. Looks like the best way to change it is to suction it out. Anyone have any other ideas without taking it apart?
How do you all get the oil out of a gearbox that doesn't have a drain plug?? Besides turning a 600lb implement upside down, or using a tube to siphon the oil out?? I need to change the gear oil in my bush hog and finish cut mower, just looking for the easiest way to do it. I think they (Harbor...
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
I bought one of the oil suction removal reservoirs a long time ago and it is a must have for gearboxes without drain plugs.
Get one and you’ll find other uses. There’s also a small one, looks like a grease gun. Might be just right for little jobs.
I use large vet syringes and rubber tubing to remove gear lube.
It's a little time consuming, but goes fast enough if the gear oil is warmed up by use.
With water contaminated oil I would get as much out as possible, a and fill / drain several times.
