As others have stated, it would be better if you described your situation (acreage, intended uses) and your abilities (can you turn a wrench and feel comfortable doing it?). I do see (in your profile) that you have 21 acres. Do you intend to clear all of that land? How much of it do you intend to improve?
After that...personally, I like the Deere 790 for it's simplicity and robust design. This is a gear tractor which may, or may not be preferable to you. Gear transmissions are cheaper then Hydros and that results in a lower initial price.
However, the 790 might be too small (as would the NH TC-30, Kubota
B2910 or equivalents). The next step up would be the 40 HP Deere 990 (again, a gear transmission).
I always suggest new owners look to the "Big Three" (Deere, New Holland or Kubota) since those companies have well established sales and service networks. The other, lesser known brands may not have the support you'll need. Since you have also posted in the Kubota forum, it appears that may be the direction you intend to go.
Mostly, the selection will depend upon your intended uses. For 21 acres, you might want to look at a larger machine...even if you go used.
