Best tractor for acreage
   / Best tractor for acreage #1
kingofallconos
Hello,
How do you judge what kind of tractor one needs? I'm coming into possession of 30 acres of workable land, and I want to get utility tractor so that I can have multiple attachments. Is an entry level tractor too big/small for 30 acres?
Thank you!
Cono
   / Best tractor for acreage #2
Welcome to the forum.
It will mainly depend on the equipment that you have, or expect to get, to work the land.
What more can you tell us about the land, your equipment plans, etc.
Might renting the land be an option?
   / Best tractor for acreage #3
Beenthere is right in that we need more information; but just guessing you will need 35HP as a minimum. However I'm guessing 40 - 50HP is more in order. Other members are more knowledgeable on that, and I hope someone chimes in. Less HP can do the job, it just takes longer.
   / Best tractor for acreage #4
It depends entirely on the upcoming tasks.
If all one does is mow a few hundred square feet around the house, a good lawn mower will do. If one is going to raise and bale hay off 25 acres, that is an entirely different equation. Row cropping yet another.
Cannot make recommendations basely purely on number of acres. Tasks determine tractor choice almost completely. Buying for long term maintenance is also important, imho. If there are just one or two giant projects, better to consider hiring or renting equipment for those.
I knew I faced ONE excavation project on my acquired property. I hired a local guy with backhoe. Cheap. Cheap. His pittance wouldn't have made even one payment on my having my own backhoe. Think smart. There is going to be a ton of other financial needs/desire associated with the property as well. Unless you have deep, deep pockets, remember the well, the fencing, the barns, sheds, drives, and so on, and on, and on.
   / Best tractor for acreage #5
For my 30 acres... my choice was a 4520.
But the question is too wide for a good answer. I needed to recover 20 of those acres from brush, do some light logging, roads, and some hay. I have enough use I went for the attachable BH. I wanted a tractor for 80% 3pt, 20% BH. If the ratio was 50-50 or less I would have gone with a 110 TLB. I need the higher HP for my use.
I did wind up buying a smaller unit for the around the house chores, the 4520 was too big. The 2305 wouldn't have done the big chores I needed though. I used to have a 4300 and it was too small as well for the big uses.
One issue I have is limited time. So I need the tractor available when I need it, so renting was not a viable option for me. The hour each way to the rental yard would have killed much of my time.
Hello,
Thanks for the responses. I'm pretty new to the farming. I'm just in the process of putting together a budget for a hobby farm. I'm purchasing 114 acres of vacant land, with 50 acres workable. The rest is heavily wooded and filled with wild game. There are some sporadic trees I need to clear but the land is flat and does not require any draining. I do not want to rent a tractor.
35 acres for agriculture use
10 acres for pasture
I'm starting from the scratch. The lI need to till the land, clear brush. Then plant for 35 acres.
I'm planting potatoes and classic tomatoes and hay. In the winter I will plant oats.
Sorry if I'm not providing sufficient information, I'm still learning the right questions to ask! :) I have a lot of knowledge gaps to cover.
Cheers,
Cono
   / Best tractor for acreage #7
Thanks for the additional information.
The tasks you describe will require lots study and more than a few test drives at a helpful, lower pressure dealership.
You gonna need a big one!! Seriously, you will want a stout machine for those tasks. Just saying 50-60 hp doesn't help all that much, as the variety of machines at this level is very diverse and the options that accompany them are extensive. What might prove difficult is the dialing in of the finer points of the different models at that level. Take your time. You will be a bit overwhelmed at first, but slowly and surely, the minutia begins to make sense. Again, Take your time.
   / Best tractor for acreage #8
Cono welcome to the forum and congratulations on the new property. Your laying out some big projects for yourself. Potatoes and tomatoes require a lot of hand work without some specialized equipment that is expensive. The problem there is expensive equipment requires planting a lot of acreage to pay for itself. Hay falls into the same category and is seldom practical on small acreage unless you are very good at keeping older equipment running. If there is a lot of hay done in your area you can often work out a deal with farmers to do your hay for shares. If you are set on doing your own hay I would not consider a tractor under 60 hp.
Given that you are still at the research stage talk with your local county extension agent. They will know what grows, how to grow it and who else grows it in your area.
One last thing, if you are trying to do it for profit it is awful hard to break even on 35 acres.
MarkV
   / Best tractor for acreage #9
You may want to investigate the equipment you will need for your different jobs and how serious you are about them. Will they be required to be money makers or will the hobby farm be supported by other means.
Haying equipment is expensive unless you can buy older and be able to fix them yourself. It may require larger HP.
Will you harvest the oat grain or oats or use the entire plant for feed.
The original cultivation has been done in the past with 25 HP tractors, ploughs, disk's cultivator etc. Just takes time.
The potaoes take special equipment as will the tomatoes.
You'll have to determine what equipment you need and then choose the tractor to handle it.:D
Sorry to be of no positive help but there is a lot more involved than just a tractor.:eek:
   / Best tractor for acreage #10
kingofallconos,
Aquiring new property can be very exciting and it is rewarding to be able to look over improvements you have made with satisfaction. How you change the landscape, how you use it and what your expectations or goals are need to be well thought out. The experience you are looking for is developed over time, what type and size equipment is a minor part of the big picture.
I agree with other posters to take it slow, and I would be careful not to assume that farming is going to pay the note on the land. If it were easy to make this work all of us here would be riding tractors and buying land instead of riding computers. Most of us here enjoy the time spent on our land and our tractors, for most of us we subsidize it because it is a fun lifestyle.
I suggest you spend some time walking the land with your family to get a better feel for it. Inquire and observe how others in your locale are utilizing their land. Figure out how much time you have to spend, what your long term goals are and how you can achieve these goals. Know how you are going to pay for it.
Once you can ask more specific questions, hopefully we can offer more specific suggestions.
Coleman 274BH Lantern Edition Travel Trailer (A51694)
Coleman 274BH...
9202 (A50322)
9202 (A50322)
BUSH HOG 7007 LOT IDENTIFIER 38 (A53084)
BUSH HOG 7007 LOT...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
New Holland B95B (A50123)
New Holland B95B...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
