Best tools to level sifted topsoil for nice yard
   / Best tools to level sifted topsoil for nice yard #1
TractorDale
fairfield, ct
TC 29DA
I've been working on my back yard - about 1 acre, sloping away from the house. So far have been spreading clean fill in an attempt to get it flat, will be having topsoil delivered soon. What would be the easiest way to get the dirt fairly flat (with grade for drainage). Box blade? Rear blade? Harrow? Garden rake and a few cases of Yuengling?
Thanks for your thoughts.
Dale
tc29
   / Best tools to level sifted topsoil for nice yard #2
Sounds like your list is backwards, I like a disc followed by a blade turned backwards to press down lightly,packing down and moving some of the high spots.IMO.A rake helps to keep it fluffy if desired or needed,a light rain won't wash it away as bad as semi packed.
   / Best tools to level sifted topsoil for nice yard #3
Your entire list is appropriate... even a rr tie dragged behind. I use a 12' wide oval shaped 'c' channel scrap steel dragged behind a gator, wider = smoother faster. Be patient drive in figure 8's till your'e done
   / Best tools to level sifted topsoil for nice yard #4
A rear blade that is angled about 30* to 45* works pretty good for leveling dirt. The angle moves dirt from high spots into low spots and will not follow the contour of the land as much and make it worse like a non-angled blade will do. First, move the dirt from the high spots to the low spots the best that you can by raising and lowering the 3PTH. Second, once the ground is as level as you can get it, start making passes back and forth with the angled blade. Third, Fourth, Fifth,.... go over it again and again at right angles each time until it is level enough to suit you. Another thing that helps a lot is skid shoes. They help keep the blade from moving down into every little low spot. The rear blade is cheap and if you already own one you are all set. I have leveled some pretty uneven ground that way. It takes time but the results will come.
Pics are a before and after look at my backyard project that I leveled with a RB.
   / Best tools to level sifted topsoil for nice yard #5
Toolguys description of the back blade will work well. The skid shoes or gauge wheels really help. :D
The trick is to keep moving a windrow of dirt back and forth. Rota tilling prior and during the blading will also help.
Thanks for the advice gentlemen- will invest in a rear blade with skid shoes.
Dale
   / Best tools to level sifted topsoil for nice yard #7
I use a landscape rake for leveling; You need the guage wheels to keep it level; (acts like a roadgrader) You said to level it. Without wheels you will not get it level; blades etc. will follow movement of tractor. I finish lawns with a harley power rake. This is a final pass that levels very well.
   / Best tools to level sifted topsoil for nice yard #8
I am actually surprised, I would think the Box Blade would be a natural for this application. I know it would be the tool I would choose.
   / Best tools to level sifted topsoil for nice yard #9
Box blades have their place but for leveling large areas they have limitations. They cannot roll a windrow of dirt back and forth which is required for good leveling.:D :D
   / Best tools to level sifted topsoil for nice yard #10
If you position the box blade just above the ground about two inches, it does indeed work well for leveling. Make circles or preferably figures 8s and you will have the area level in a while. The more level that it gets the closer you can position it to the ground. I much prefer my box to a straight rear blade for leveling.
2018 Wacker Neuson RTLX-SC3 Trench Compactor (A44391)
2018 Wacker Neuson...
APEX Ag Equipment Hyperdisc H18/20 | High-Performance Tillage Disc for Precision Farming (A44789)
APEX Ag Equipment...
Skid Steer Tree Puller Attachment (A39855)
Skid Steer Tree...
Fork Extensions (A44391)
Fork Extensions...
2005 Toyota Highlander SUV (A42744)
2005 Toyota...
NEW POULAN WEEDEATER NEW SUPPORT EQUIPMENT (A40018)
NEW POULAN...
