Best solution for retaining wall needed
   / Best solution for retaining wall needed #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've about 50' of retaining wall built of RR ties I need to replace. It's about 2' tall for the most part. A short section might be 3'.
I'm in the country so no engineering or permit needed. I was planning on using mostly "bin blocks". My M4700 can handle one on the 3 point, my trailer can handle 3 and it looked like an elegant solution.
But now the local places I've called are saying they won't have any for 6 months.
Other suggested solutions?
   / Best solution for retaining wall needed #2
I'd say wait for what you want, unless it's an emergency?
   / Best solution for retaining wall needed #3
I guess you could hurry up and wait or shop around. Hopefully, some hungry outfit would even sweeten the deal with delivery. Don't mess up the ascetics you are looking for by settling for less.
   / Best solution for retaining wall needed #4
OK - I looked it up - "bin blocks". I thought you were talking about those highway barrier blocks. The ones around here weigh 4700# to 5000#+. Bin blocks would make a very nice looking retaining wall.
   / Best solution for retaining wall needed #5
Ready mix companies are gearing up for the season and typically only cast bin blocks from partial loads that come back or miss-orders. Its a great way to use surplus concrete (that someone else already paid for). They'll be casting them all summer long, so if you can wait, there will be a stock built up in September or so.
   / Best solution for retaining wall needed #6
I use mortarless blocks. You see huge walls of them done commercially all over. I've done 2 or 3. So easy to do.
2014 Ford Fusion Sedan (A48082)
2014 Ford Fusion...
Daewoo G25E-3 Forklift (A50860)
Daewoo G25E-3...
2012 Ford F-350 Omaha Crane Service Truck (A48081)
2012 Ford F-350...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A48081)
2009 Hino 268...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
