Rotary Cutter Best Rotary Cutter
   / Best Rotary Cutter #1
Bwhite
Texas
I am looking at buying a 95 hp tractor with a cutter. They are recomending the 15 foot Land Pride over the 14 foot fixed Rhino and 14 foot fixed Bush Hog. Anyone have any thoughts? I will be cutting grass and fairly heavy brush. Thanks.
   / Best Rotary Cutter #2
</font><font color="blue" class="small">( Anyone have any thoughts? )</font>
The Rhino 15' Flexwing Heavy or Super-Heavy Duty model. It is hands the best rotary cutter in it's class.
Why did he compare the Flexwing Land Pride vs. a Rhino 14' fixed deck? Because he knew if he compared Flexwing to Flexwing he couldn't recommend the Land Pride.
Actually the Rhino Fixed Deck is better too, but unless you have flat land, you will get scalping and high spots on your non-flat areas.
   / Best Rotary Cutter #3
Sounds weird... I'd buy either the Rhino or the Bush hog over landpride... Cutters are what they do best. I'd give a slight edge to the Heavy Rhino but I could easily buy the bush hog in the 3615 model for the right deal. Whatever you get, get the chains on both front and back to catch flying stuff...
how much are the FL15 Rhino? He quoted me $15,000
   / Best Rotary Cutter #5
The SR15 is heavier than the BH-3615, heavier gearboxes and drives. $10,300
   / Best Rotary Cutter #6
These prices should give you an idea of how good/bad of a deal you are getting.
You really don't need an FL-15 (Super-Heavy Duty), I'd recommend an SR-15. I would think once you get your initial brush cut, you'll just be cutting grass after that.
If you were going to use your cutter on brush all the time, I'd then go with the FL-15.
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2007 CATERPILLAR D6N LGP HI TRACK CRAWLER DOZER (A51242)
2007 CATERPILLAR...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
John Deere LX5 3 pt Rotary Mower (A50515)
John Deere LX5 3...
