Rake Best Rake for the $
   / Best Rake for the $ #1
keywest
S.E.Mass.
BX - 23
Hi Guys,
I have a BX-23 & I would like to get a 3 pt. Landscape Rake to maintain a gravel driveway & other chores around the place.
My trouble is my limited funds after the BX purchase.
My wife feels I have enough Toys around to keep me going But she just does'nt understand! Right???
Please help me out - I do want to get a decent Rake but would really like to keep the Cost down....
Thanks, Paul /forums/images/graemlins/ooo.gif
   / Best Rake for the $ #2
I would delay your purchase towards spring and try to save some money for it over the winter. I have a BX23 also and plan on getting the woods estate rake with gage wheels. With winter coming I won't be using it much now. This rake is designed for the BX tractor and likely easier to maneuver. I think king cutter may make a similar one. I had a woods 60' landscape rake for my prior B2410 and I would not want this big of a rake for the BX. Besides the estate rake will require less space and be easier to hook up. The cost may be more than a bargain rake but its maneuverability would be worth it to me.
Nik,
Thanks for your input. I'll take a look @ those estate rake's. They sound expensive from the name though.
I'll keep an open mind.
Thank's again, Paul /forums/images/graemlins/smile.gif
   / Best Rake for the $ #4
The Woods Estate equipment is more expensive than normal CAT1 implements I believe. I bought a Woods Estate series box blade for my BX23 this summer and it works great but I remember I paid more for it than I would have if I got another brand like Midwest or one of the other good brands. When I wanted to put a rear grader blade on the BX23 I looked around and decided that the Midwest RB22-60 was the one that I wanted. There were numerous postings on how the Midwest implements did not work on the BX series tractor because of the lift on the 3pt - but I came up with a solution that is working very well. Using some 5x5 3/8" thick angle iron I made a couple of extensions for each corner of the front mount on the blade that extend the pins downward approximately 5 inches. Then I redrilled a hole in the upper mounting piece of the blade to lower the upper mounting hole also. I also use a Speeco quick hitch so the blade was setup with the bushings for the quick hitch also. With this setup I get as much lift out of the blade as I get with Woods box blade and I have used the blade to pull enough earth that I totally bogged down the tractor and did not have any problems with them bending or distorting etc. So after saying all this I would say that if I was looking for a rake you should also look at the Midwest units - they can be adapted to work on the BX. Oh yeah - one more thing - the rear blade I got is actually a Kioti - made for them by Midwest. There were no Midwest dealers I could find in my area that had the blade in the stock but I found a Kioti dealer with one - and the Kioti orange color matches the Kubota perfectly. If there is a Kioti dealer in your area you might want to take a look.
2020 CATERPILLAR 938M WHEEL LOADER (A51242)
2020 CATERPILLAR...
2007 Toyota Camry (A50324)
2007 Toyota Camry...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Texas Built 25' Stand Alone Inline Feeder (A50515)
Texas Built 25'...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
