best place to buy a rear remote kit -new holland
   / best place to buy a rear remote kit -new holland #1
hotchkiss
Ohio
JD 6330, JD 5055e, Ford 4000,
I am going to add a second rear remote to a New Holland TN-95A. Where is a good place to order the kit on line?
   / best place to buy a rear remote kit -new holland #4
A stacked valved will allow you to select the options you need on each spool.
The cost on a valve from Surplus or Baileys will be a lot less.
If you have the ability, you can come up with the parts to install, say a 3 or 4 spool remote valve and save money, and learn something also.
Some of your options may include things like float, detents, motor spool, etc.
Stacked valve will also allow you to add more spools in the future if needed.
Something like this.
Surplus Center - 4 SPOOL SV VALVE OPEN CENTER W/POWER BEYOND
Check with NH to see if they have a remote kit.
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
