Dargo
Super Member
- Joined
- Mar 6, 2004
- Messages
- 5,981
- Location
- S. IN
- Tractor
- Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
I've done a lot in digging but I'm a pure novice in handling underground water and getting rid of surface water on a field from below. As I've posted on here before, I put a soccer field in my back yard for my daughter's teams to practice on. Unfortunately, that flat(ish) area has several underground springs that stay active until about June. I also pick up some run off that goes into my lake.
I've heard so many ways to get the water and put in my first set of lines, but I'm not sure what the best method is. Going through the worst area, just north of the soccer field, I trenched in a 2' wide trench only about 2' deep all down the side terminating in my lake. I lined the bottom of the slop pit (what it looked like within an hour) with a few inches of gravel and then put in two 4" perforated corrugated with fabric sock lines on each side of the trench. I then put in a few more inches of #2 gravel to hold them in place and keep them from floating. At the pond I just built a small box of plywood with two 4 1/2" holds in them that empty just under the waterline. I drove two 1/2" pieces of rebar over each pope in an "X" shape just to hold them down to the natural level of emptying into the pond and mixed up a couple 80 pound bags of concrete and poured around the pipes. This seems a must from past drains (downspout) that terminate into the pond. Without the concrete collar of sort, either fish or something seems to like digging back next to the pipes.
Anyway, it's rained about an inch or two every 2 or 3 days since I did that first run. It's hard to tell if it's working well or not since it's still such a soupy mess. I can crumble a small dirt clod over the end of the pipes in the lake and there obviously is flow from them yet those two lines clearly aren't keeping up. Before I go trenching up the rest of the field I was curious of how other people have handled similar tasks. I'd planned on just zig-zagging down the field and doing the same thing. Obviously, it's also getting expensive. The company I buy the pipe from tells me that I can skip the gravel part and their commercial customers just install the perforated socked pipe without gravel. Other people have told me that they have skipped the pipe and just made gravel runs covered with landscaping fabric. It seems like dirt will eventually clog that, but I don't know. Thoughts...as I watch it rain more?
