best implement for the job
   / best implement for the job #1
Anonymous Poster
Epic Contributor
I have a lot which is in bad condition. It is uneven, rutted, and bumpy. Mowing it with my TC25D and 3pt bush hog finish mower takes a lot longer than it should because of the roughness. I would like to break it up and level it, then plant new grass seed. The dirt in my area of NJ is very fine. almost clay-like dirt, which gets very hard and dry in the summer. I'm not sure what implement to use to do the job. Should I disk it, then use a york rake or harrow drag; or should I use a box blade? Something else?? Any suggestions would be greatly appreciated.
   / best implement for the job #2
That's what I use my boxblade for - well, one of the things I use it for anyway -
mike
   / best implement for the job #3
How big is the lot? I'd be surprised if a disk that a TC25D could pull would be heavy enough to break things up. Our 3 acre field was somewhat similar to yours and we had to have a farmer with a full size tractor and a huge disk first disk the field (to chew up the remains of a corn crop), then plow the field then disk it again to get it level. We then had the field limed (based upon a soil test - highly recommended). The farmer will be back soon to plant the grass seed using a seeder.
If the lot isn't too big, I'd think the box blade would be best, then a drag harrow, lime (if indicated by a soil test), seed, then drag harrow again to cover the seed.
   / best implement for the job #4
If you are going to seed it, I think you eventually will want to use a york rake to finish it and prepare the bed. I've used a disk myself in a similar situation, but if the ground is at all hard-packed you end up spending a lot of time going over it. If you break it up with a disk, will you be able to level it with the rake or do you think it's uneven enough you'll still have to use a blade? Don't know if you've raked much, but my experience is it creates the perfect seadbed. Try to find a rake with gage wheels however, otherwise it's a little trickier and not nearly as easy. Good Luck nomatter.
The lot isn't too big. I'd say about 1 acre.
   / best implement for the job #6
I will be faced with the same thing once our house is finished. All sorts of ruts from the construction traffic. I was going to suggest a disc then drags and finally the rake but if your lot is only an acre how about tilling the whole thing then the rake? If I didn't have so much area to do, that would be my plan.
No matter what you do, the moisture content will play a huge role in your success. You may have to try under various conditions to get the best soil "workability" /w3tcompact/icons/smile.gif
   / best implement for the job #7
Howdy!
By virtue of default, I recently did something similar. We had a bunch of large oaks die on us last year, and we made the decision to cut them down and make a nice grassy area of it.
With the trees down, I was left with a really unlevel, uneven area. So, I just took to working it with the toothbar on my loader. What I did was to point the teeth down into the dirt, and drive backwards. Some areas dug in nicely -- some took a few passes. When I had the whole area "roughed up," I then went and backdragged the bucket using the heel of the bucket to create a smooth finish. This really smoothed out the tooth bar furrows, but didn't smooth things out so much that the seed didn't have a place to stick. Then, I broadcast a strudy kentucky fescue seed, and left it alone.
That was in February and the new "yard" is starting to really green up. My wife is pretty pleased and it was a more accurate and controlled process than a blade or box blade.
Just a suggestion...
Best Regards,
Jay
   / best implement for the job #8
Here's what I do when faced w/an undertaking like you have. I use a cultivator or let down the scarfires on my boxblade and rip the place to pieces. I then follow up w/my tiller as you will get a much better result w/it after the aforementioned step. I then use my rake to get any rocks or roots out of the way. Last but not least it's pulverizer time and wallah...you're through. I didn't go into detail about the proper method for seeding but if you'd like to know just ask away.
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
County Line 5' Poly Feed Trough (A50515)
County Line 5'...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
Gehl 2580 Round Baler (A50774)
Gehl 2580 Round...
