Best disk harrows?
   / Best disk harrows? #1
Mitigator33
Bronze Member
Eastern Alabama
John Deere 5083E
If Money was not an issue and you could buy any set of disk harrows you wanted what would you buy given the following parameters?
I run an 83hp tractor John Deere 5083E
Must be at least 8 ft in width or greater
Must be portable (can be put on a trailer and moved to multiple sights)
Easy to adjust gangs
Heavy (I want it to do work not just scratch the surface)
Well built and easy to work on for maintenance
The primary use-Food plots for wildlife as well as pasture maintenance and creation of seed bed for pasture
Implements I already own:
Box blade 8ft
Rake
5 disc 3point plow
Cultipacker
Bush Hog
Old cheap disc that are way too light for my current use and too small for my tractor
FEL
Pallet Forks
I will turn my plots every 2-4 years with the plow but for maintenance/cutting fire breaks/seed bed prep I need a good set of disk. I am not a JD nut to the point that I care what color my implements are I just want a good one. I can't run a tiller due to the amount of roots and rocks in my soil.
I am leaning toward Brown Manufacturing because of the weight and ease of adjusting the gangs. Any others I should look at? Thank you in advance.
   / Best disk harrows? #2
I like my farm king. It was about 2800. I added a few hundred lbs to it. 8 and a half foot. Land pride has some nice stuff
   / Best disk harrows? #3
Landpride DH 2596 with notched front and rear disc blades.
   / Best disk harrows? #6
Frontier 1386, Atlas 1500 and check the Athens site. They have some 3PT units that get pretty heavy.
I was looking for one last year for my JD 5303 and wound up buying a used Long brand unit with 4" frame and rebuilt it. Figure I got about 1/3 to 1/2 price of new comparable unit.
Thanks to all. I have several of these dealers close to me and will check them out. The Atlas is made right here in Alabama and I always like to keep it local if I can. Does anyone know if the Atlas has a quick gang adjustment?
Question on the frontier that was mentioned...it states that it is for up to 75 HP tractor max. Mine is an 83hp. Is this an issue?
   / Best disk harrows? #9
Mitigator, I too live in Bama. I have a 70hp kubota and Lowery mfg out of Boaz makes a heavy duty disc that I bought this year. I would check them out. Just google "lowery mfg". Well priced, too.
   / Best disk harrows? #10
I have your tractor and pull a 8 ft athens offset with 24" disks. It will definitely do work, but not so good as a finisher. Then I have a 12' Krause that finishes well but is way too light for primary tillage and is weighted down with railroad rails. I want a 10' Athens with 22" disks that weighs about 150# per disk.
2022 Chevrolet 5500HD AMH 22ft Box Truck (A42742)
2022 Chevrolet...
2006 INTERNATIONAL 4300 DIGGER DEREK (A43003)
2006 INTERNATIONAL...
Ingersoll Rand Shell Kit (A42021)
Ingersoll Rand...
2019 TY-CROP MANUFACTURING LTD DRY BULK TRANSPORT TRAILER (A45333)
2019 TY-CROP...
New/Unused 2025 QH12R Mini Excavator (A44391)
New/Unused 2025...
John Deere HPX Gator (A44500)
John Deere HPX...
