Best clutch for 375 MF 4wd
   / Best clutch for 375 MF 4wd #1
Overkill338
1987 Massey Ferguson 375 4wd
We use it for commercial mowing in the medians. So having to trim around the city's trees, there is a lot of pull up, back up, pull up, back up etc etc etc.
The clutch had been releasing at the top, but today it started slipping. So I called it a day and drove it back to our yard. It wouldn't even pull hills in 3rd gear any more, it would start slipping. So I drove 6 miles, at 3-5 mph lol
Anyway, the clutches I've been looking at online don't say which ones are standard and which are heavy duty. I'm assuming the one that utilizes a clutch disc with 5 tabs sticking off of it, is the more heavy duty clutch. But I hope someone here can point me in the correct direction.
Thanks in Advance.
How can I tell if this tractor has the dual clutch, or split torque clutch.
   / Best clutch for 375 MF 4wd #3
If it's the multipower transmission and or has independent PTO it will be a split torque. Non multipower tractors with live PTO have the dual clutch.
There is a cover under the bell housing held on with four bolts. With cover removed you can see the clutch through the exposed opening.
It has proven to be a hell of a tractor! My boss has a 9540 Kubota and this MF would pull that Kubota apart. The Kubota was buried to almost the doors, and the ole MF pulled it out like it was nothing. Needs repainted, but it only shows 2089 hours now.
By the way, the PTO is independent, and it has the 12 speed with 3 sticks.
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
Loftness Mulching Head (A51573)
Loftness Mulching...
43030 (A51691)
43030 (A51691)
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
