best chinese tractor
/ best chinese tractor #1
helpme
suffolk co. n.y.
looking at jinma and kama brand tractors, probably 35 or 45 hp. plan on alot of digging in rocky heavy soil.also looking for most reliable dealer closest to long island n.y. thanks H
/ best chinese tractor #2
Greetings Helpme, and welcome to the forum,
First, I think first I should request some info from you. Why don't you fill out your bio and tell us why you want a China brand tractor, what you intend to use it for? (as per your "a lot of digging" statement). Also let us know your mechanical abilities?
The reason I ask for this info is a China tractor may not be for everyone. They are fine workhorses, don't get me wrong but need an occasional "tweak" now and then. I own a Jinma and feel very comfortable with mine but I am a mechanic.
So we would need this info from you so we could give our best recommendations to you.
Regards, Harry in Upstate NY /forums/images/graemlins/smile.gif
/ best chinese tractor #3
on the 35 and up HP i say the Kama hands down. Fit and finish is better on the 45HP and up Kama and it is just a nicer tractor for the money.
now i have not seen the new Jinma 45and up HP but if the fit and finish is the same on them as the 284 then i can say go Kama.
the reason I want a chinese tractor is that I am not made of money. I plan on doing alot of work at my (retirement vacation) house in upstate N.Y. (w. burlington , otsego co.). Some experience on tractors when I was younger but havent been on a tractor in years. Luckily I am handy at anything I set my mind to. Therefore I dont forsee problems dealing with maintenance on these tractors. thanks. helpme
/ best chinese tractor #5
</font><font color="blue" class="small">( the reason I want a chinese tractor is that I am not made of money. . Luckily I am handy at anything I set my mind to. Therefore I dont forsee problems dealing with maintenance on these tractors. thanks. helpme )</font>
Hello Helpme,
Most of us are getting the Foreign Brand Tractors, Especially the Chinese Tractors, for the same reason.
I chose Chinese, because I couldn't spend the extra money's for a Well Know Brand, such as JD, MF, NH, and now even Kabota has got a dollar amount attached to their name. And I thought buying used was just as much of a gamble, versus buying New Chinese.
Buying Chinese is a littlebit like being a pioneer and a gambler. To break away from the herd,, you've got to take advantage of your past knowledge and build upon it, and take what the Competition says with a grain of salt.
I don't think that the Chinese tractors are as good as the JD, MF, Kabota and some others, but the Chinese Tractors are at about 1/2 the price or even less, if you shop hard.
My first Chinese Tractor was a Shinniu. I got it in 1990 for 5K and sold it in 1997 for 4K. i bought my 2nd Chinese TRactor in 2003 and so far so good.
Just Remember, when you get Chinese,, you arn't running with the Herd anymore and it gets pretty breazy sometimes, when you are out pioneering on your own.
These forums are great though and you can get a wealth of knowledge about previous breakdowns and errors that others have made, that you can take advantage of. So I suggest you read as many of the posts here on this forum and also at the NYCTO forum, and anyother tractor forum that you can get your hands on.
Although Parts does not seem to be a problem with the Jinma's, there are so many of these tractor here now,, that there is at least one place that stocks OEM filters and either has or can get the OEM parts that you need.
But the biggest problem, that I have came across is, Getting Geniune Technical Support. Too many saying one thing and Too many saying something else. The issue now that is up for Debate: What is the correct VAlve Lash on a Y380T Engine, Some say one thing and others say something else, and No one seems to be able to get technical support from Either Jinma or YangDong(Engine Manufacturer).
Which ever Tractor that you get,, make sure since you are saving money anyway, to get all of the Creature Comforts that you desire, such as PS, 4Wd, Spring Suspension Seat for Body weight, Canopy. And if you live where it is freezing cold most of the time,, consider getting a cab with a heater, and anyother feature that you can think of from the getgo, so you get the tractor setup just the way that you want it.
Have a nice day,
Joe /forums/images/graemlins/cool.gif
/ best chinese tractor #6
</font><font color="blue" class="small">( the reason I want a chinese tractor is that I am not made of money. I plan on doing alot of work at my (retirement vacation) house in upstate N.Y. (w. burlington , otsego co.). Some experience on tractors when I was younger but havent been on a tractor in years. Luckily I am handy at anything I set my mind to. Therefore I dont forsee problems dealing with maintenance on these tractors. thanks. helpme )</font>
Well Helpme, I think you are a perfect canidate for a China tractor. /forums/images/graemlins/grin.gif Just like the rest of us.
We just have to fit the right size unit to fit your needs. You said a lot of digging. Anything else like mowing large areas, or anything that may require special features like steep hill work? Tight areas where size is a factor?
Just trying to fix you up with best available info and recommendations. Kama and Jinma are two brands that may suit your needs.
HI Harry, there will be a little finish mowing but for the most part the field work will consist of brushoging. some planting, erecting fences, rototilling for gardens, and ofcourse grading my 1300 foot driveway. As for the lay of the land, its mostly flat with one pretty steep area, about 3 acres, the attachments I will need is fel, phd, brushog, and backhoe. But I anticepate buying more because I like to play. thanks helpme
/ best chinese tractor #8
Well, if you have 16 acres and want to do what you say I would think a 35 HP would be a minimum. You can always go for more HP. I have a lot of good things about Kama. I believe there is a guy on this board with a Kama from Orange county NY that maybe could show you his and you could get a feel of the machine.
I have a 224 Jinma and would gladly show you mine but I think mine is too small for what you need.
Yes, the more I think about your needs( some steep hills, long driveway, etc) I think 45 HP Kama would best suit your needs.
Maybe others could add to my suggestions.
/ best chinese tractor #9
I'm one of the 45hp KAMA guys. Be more than happy to answer any specific questions you may have.
//greg//
/ best chinese tractor #10
Helpme .. I'm that guy from Orange County NY with the KM454. I'd be happy to have you over if you want to try before you buy. I'm probably 2- 2.5 hrs from you if your up for a road trip. If you plan on working hard, which it sounds like you do you'll be happy with the 454. PM me if you have any specific questions or are interested in taking a looksee...Scozz
/ best chinese tractor #11
If you plan on doing tilling I don't think the shuttle shift has a low enough gear for that so check on that.
Mark H
/ best chinese tractor #12
</font><font color="blue" class="small">( If you plan on doing tilling I don't think the shuttle shift has a low enough gear for that so check on that. )</font>
If you've got 45hp Mark, you don't NEED a creeper gear.
//greg//
/ best chinese tractor #13
If it helps any, I have a 284 LE Jinma and I really like the tractor so far (60 + hours) The one thing that I wish mine had is more lifting capacity on the 3ph and the FEL. Greg-g and Chip can help you with the bigger tractor and for your size of acreage I would go for the 45 hp Kama. You should have the power to do anything you want to do.
/ best chinese tractor #14
helpme, I live in western CT and have a Jinma 204 with bucket and backhoe and a bunch of other stuff for it. You're more than welcome to come by and try it out. We use it for a small landscaping business we have and love it. Can't imagine the power a 35 or-45 hp tractor would have.
By the way we'll be neighbors in upstate as well. We have a place in Norwich.
/ best chinese tractor #15
Hi Help me
Well Id like to throw a wrench into this post and suggest you also have a look at the new 2005 Taskmaster Tractors, they are built by Dong Feng in China are an option no one ever talks about they have a 32 hp model that will fit your needs.
Just a thought should you require any other info pls let me know.
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
MASSAGE CHAIR (A58214)
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
2013 Volkswagen Diesel Passat TDI Sedan (A61569)
2013 Volkswagen...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
