Best brand/price for 3.5 Ton UTV Winch....
   / Best brand/price for 3.5 Ton UTV Winch.... #1
Coyote machine
Super Member
Southern VT
22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Looking to buy a 3.5 ton +/- winch for my 2016 model year Kioti Mechron 2200PS. The UTV weighs 2000#s approximately, (1 ton); and has a built in winch mounting plate and grille already in place from the factory.
I'd also like to know what one would do regarding wiring up an aftermarket winch, and getting a dash switch etc. installed...
Any help appreciated,
TIA,
CM
   / Best brand/price for 3.5 Ton UTV Winch.... #2
I'm no expert on this, but Harbor Freight has the "Badland" line of winches (go to harborfreight.com and search for badland winch). They are inexpensive - probably not as good as some of the big name winches, but I've had good luck with my 3500# winch. They usually list for $130, but they go on sale fairly regularly. It saw some decent use on a work sight where there was no power available, so we'd hook it up to a deep cycle battery and recharge on our lunch break. I'm about to mount it on an antique Coot ATV/UTV.
I could have gotten by with a 2000 or 2500# winch, but I got the larger unit for two reasons: (1) it's significantly faster than the 2000# winch (I'm used to the speed of a PTO-driven logging winch on my tractor, and electric winches are painfully slow by comparison) and (2) I figured I'd have fewer problems running into the duty cycle limit using a larger winch on a lighter pull, than if I were maxing out a smaller unit.
   / Best brand/price for 3.5 Ton UTV Winch.... #3
CM
I think if you burry that UTV in mud, 3500 may not be a big enough winch... Personally, I'd want a bigger winch on there.
SR
   / Best brand/price for 3.5 Ton UTV Winch.... #4
I agree with Rob. 4K minimum.
I have 3 winches that I use regularly. They are all Warn. Expensive. Fast. Low amp draw.
I wheel with a group of guys that have various brands of winches. A cheap winch will get you out of a pinch. Patience is required. High quality battery required. High output alternator required.
The patience thing you can't escape. You can avoid the battery and alternator requirement if you are willing to add to the patience requirement. :)
In winches, my 30 years of experience with them has taught me you get what you pay for. :)
   / Best brand/price for 3.5 Ton UTV Winch.... #5
This is the one I plan on getting for my Honda Pioneer.
Amazon.com: Superwinch 113522 Terra 35 35lbs/1591kg single line pull with roller fairlead, handlebar mnt toggle, handheld remote: Automotive
I'm on a couple of the UTV forums and they get very high praise from the members who own them. I agree that the Warn winches are great, but the high cost for something I'll rarely if ever use had me looking at other options.
For my install I'm going to add a second battery and an isolator to power the winch. That way I'll always have power and won't drain my main battery.
   / Best brand/price for 3.5 Ton UTV Winch.... #6
As indicated by ocrszd - in winches, you will only get what you pay for. If you are going to be in serious winching situations get a Warn. Otherwise, get something that looks good on the front of your UTV.
   / Best brand/price for 3.5 Ton UTV Winch.... #7
SR
OP stated a 3.5Ton +/-, which would be a 7000#, way more than the 3500 or 4K you all are reading it as.
   / Best brand/price for 3.5 Ton UTV Winch.... #8
I've used winches, in serious situations, since 1967. They have always been Warn winches. I would suggest rather than a dash mounted switch - get a toggle switch on a 20 foot extension cord. This way you can - if two people are there - be outside the vehicle controlling the winch and watching how the cable is spooling up. Second person is in the vehicle driving. Only one person - bring the control toggle switch inside the vehicle, thru an open window, so you can control the vehicle & winch at the same time.
   / Best brand/price for 3.5 Ton UTV Winch.... #9
First, vehicle winches aren't rated in "tons", they're rated by thousands of pounds of pulling power. Nobody makes a 7k winch, so you're looking at an 8 or 9k winch if you want to be above that, or a 5-6k winch below. IMO, anything bigger than about 5k is too much winch for a SxS. You do want something that will get you out, but you do NOT want something that will do damage if you get snagged...
You also need to match the winch to the battery, and since you have a built in winch mount plate, to the plate. My guess is that the battery is smaller than a standard auto battery, and that the winch plate is sized for a 3500lb winch. You might get a 4500 or 5k winch to bolt up at the top end, but bigger than that and the winch probably won't fit, let alone bolt up, and a bigger winch will kill your small battery if you use it much.
Measure the bolt pattern on your plate, and see how that compares to a 3500-5k winch. HF has the measurements on their site for their winches. I have two HF winches, a HF 3500 and a 5000lb. Both mounted to cradles. I use the 3500 on my ATV, and on my trailer. The 5k goes on the front of my wife's Jeep Comanche. Mostly used for pulling trees out of the trail, since it's usually less work than cutting them up. They've both been good winches, and I'd not hesitate to buy them again for occasional use.
If you want to spend some money, I would recommend Warn. I have an XD9000i and an 8274 that have been abused and still work great. They're both about 20 years old, and neither have ever let me down.
My experience with Smittybilt winches is from several years ago, but they were junk at that time.
Regardless of what winch you end up with, you should also get and carry a small kit of accessories, including a snatch block, clevis, choke chain, and tree saver strap. If you REALLY stick it, and single line isn't enough to get you out, you can always double line. Even with a 3500lb winch, double line gets you to 7k lbs. That's easily enough to rip off suspension parts or bend things you don't want to bend, so you have to be careful...
As for wiring, I would suggest just using the included remote, and disconnecting it when not used. HF also sells a wireless remote that works OK with their winches. I don't see the point mostly... You should be IN the vehicle when winching, and helping with the engine, not standing 50' away winching it dead...
You can add a disconnect if you like, just in case something goes wrong. Keeping it disconnected most of the time will also keep the positive lead from corroding in the weather too. Just make sure it'll flow the amperage that the winch requires.
Good luck!!
   / Best brand/price for 3.5 Ton UTV Winch.... #10
I assumed he meant 3.5K. Maybe not.
2007 National RV Dolphin Motorhome (A51694)
2007 National RV...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
