Best Bang for the Buck Kubota
   / Best Bang for the Buck Kubota #1
laen64
Ashford Alabama
Bobcat CT335 SST;FERRIS IS 1500Z 25hp 52"
I'm looking for the compact to Grand series.
30 HP--32 HP. I'm grooming 2 separate plots one yard with pretty grass 5 acre and 11 acres previously used for peanuts. Let me know what you think?
   / Best Bang for the Buck Kubota #2
Look at the L3240 HST Plus. I just traded a B7500 HST for a L3940 HST. It was delivered last Friday. We had rain and snow all weekend. May get to use it some next weekend.
   / Best Bang for the Buck Kubota #3
If your going to be finish mowing, the B3030 is a good fit. It is relatively light and has high horsepower for its weight. You can even get a cab model. I believe Kubota is the only company that offers a factory cab tractor in that size range with heat and air-conditioning.
If finish mowing is not in your plans, like the other poster stated, get a Grand L3240. It is the best bang for the buck in the Grand L series.
I actually owned a B3030 cab model and I upgraded three months or so ago to a Grand L3240. But I use my tractor mainly for loader and 3pt work, no mowing. The Grand L provides a much stronger loader than the "B" series.
   / Best Bang for the Buck Kubota #4
I started with a BX2200 5 years ago. Traded it to a B7800 4 years ago. This past summer I traded the B7800 to a L3240HST Plus. I also had a BX1500 and traded it to a BX2350. I use the BX now for all mowing. Most of my heavy loader work is done and I wish I had a B3200 instead of the L3240HST and a few thousand dollars in my pocket. The L does ride good but not a few thousand dollars better. My experience, my opinion.
   / Best Bang for the Buck Kubota #5
Look into the ownership cost of the new B3200. It will handle your grooming needs with the 72" MMM. Let us Know what you decide.... ole Ob1
   / Best Bang for the Buck Kubota #6
An L-2800 sounds like a good fit for price and size.....
   / Best Bang for the Buck Kubota #7
"one yard with pretty grass 5 acre" I would be looking at a "B" series with turf tires... but that's just MHO...
   / Best Bang for the Buck Kubota #8
Sorry but I have another thought after responding to a trailering question. Since I see you will be moving the tractor, then I would much rather trailer a B over an L due to the weight difference (check weights of each tractor). Any day any time course I don't like pulling a trailer. Never have liked it and still don't.
   / Best Bang for the Buck Kubota #9
I had the same problem. I wanted the L3240 but ended up with the B3030 because of the weight difference when trailering it.
I do believe Kubota will be the one. I'm headed to Alabama and I have to have it when I get their.
HOOAH!
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55301)
GALAXY - SET OF...
2008 Doosan Mega250-V Articulated Wheel Loader (A52377)
2008 Doosan...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
2019 MultiQuip Mayco C-30HDGA 3in Towable Concrete Pump w/ Hoses (A52377)
2019 MultiQuip...
