Best ad ons for a B series?
   / Best ad ons for a B series? #1
donn12
Platinum Member
Great Falls Virginia
B2920 TLB turfs and loaded ags
So far I would not want to be without my QA buckets and forks. Yesterday I switched 4 times moving gravel, 6x6s and digging. BTW the 60" bucket is great for gravel - no problem when full. I would not want to do this without the backhoe on though.
The other item I added which I love are the rear wheel spacers. Makes a HUGE difference in feel. To use my spreader I end up going across a decent slope and the B2920 feels more stable than my BX24 did (which also had spacers).
Anything else?
   / Best ad ons for a B series? #2
Anything else?
RatchetRake and Ferguson Overseeder.
   / Best ad ons for a B series? #4
Kubota doesn't list a quick attach for the B2920 in their builder program online. They list one for the B3200, but not for any of the smaller B models. Is this a Kubota option/attachment that just isn't listed in the builder program? Deere offers Q/A standard all the way down to the sub-compact size loaders. I'd like to throw a set of forks on for moving logs around at our cabin.
   / Best ad ons for a B series? #5
When the Quick attachment plates move the load out further and add more weight it means the attachments might cut the load carrying ability below what might be needed.
Some of the manufacturers have devised there own systems which keeps the customer coming back because there is only one manufactuer building them!
   / Best ad ons for a B series? #6
I believe the attachment points for the 2920 loader are the same as the 3200 so the QA would work fine on your loader.:thumbsup:
   / Best ad ons for a B series? #7
Yes, several of us here have purchased the B3200 QA to use on our smaller B tractors, and the QA works just fine!
   / Best ad ons for a B series? #8
And of course you all know what I like to have.:thumbsup::)
   / Best ad ons for a B series? #9
I have a B3030. Even though it came with extendible links, I really like the Pats Easy Change "slide-ins" I purchased for it. I find it much easier to hook up implements with the PECS than with the extendible links (let alone what it must be like with normal, non-extendible lower links).
The PECS replace the standard "slideable" links that come on the tractor. Slide the old ones out, slide the PECS in and you're good to go.
One nice thing about the slide-ins vs the regular PECS -- they don't increase the distance between the tractor and the implement. ie. no need to worry about changing the length of any PTO shafts.
Mini-Excavator Heavy Duty Weed, Brush, and Rock Rake (New/Unused) (A59225)
Mini-Excavator...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
EZ-GO Electric Golf Cart (A57149)
EZ-GO Electric...
2024 Superior Utility Trailer, VIN # 4M8EZ1426RD000880 (A57453)
2024 Superior...
