Berta snow casters
   / Berta snow casters #1
leonz
Super Member
NE USA
JD LA115, WH 244, Troy Built Horse 8 HP
I realise this is about snow casters but Berta has done it again!!!
They now have a 33 inch two stage snow caster with the three point hitch
mount and a solid auger, steel roller wheels or simple pas that are hand
crank adjusted that replace the wheels.
Its rated for a 14 horsepower 2 wheel mule but it has the 540 RPM PTO shaft
connection with PTO shaft guards.
It has upper and lower snow breakers and 2 cross auger shields to keep the
snow in the cross auger housing.
The images show a double acting hydraulic spout with several hinge segments
to allow high discharge angles.
I am unsure whether the chute is manually rotated or not but I believe it is rotated
by double acting hydraulics after looking at the images.
Yup it is ment for the 14 horse walk behinds but they have many narrow 4 wheel drive
mules over there that can use it.
I can see 2 of them bolted together using a chain and sprocket drive with a
center snow baffle to keep the snow from collecting between the units if they
are bolted together.
adding wings would make it a real 5 foot wide snow removal monster.
I am drooling already!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
Orthman 9300 4 row cultivator (A52128)
Orthman 9300 4 row...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
550 gal Gravity Flow Fuel Tank with Stand (A50515)
550 gal Gravity...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
JCT 72" SKID STEER QUICK ATTACH BRUSH CUTTER (A51243)
JCT 72" SKID STEER...
