Berta flail mower adjustments??
   / Berta flail mower adjustments?? #1
CodeMonkey
Orygun
Grillo 107, BCS 730
Where can I find a manual for a Berta flail mower that is in english?
The one I have is in Italian (I think) and I googled for an online manual and looked on their website and I couldn't find anything.
I looked for vids and didn't find anything there either.
I want to adjust the height, the amount of cutting (I read somewhere that you could remove a baffle or two) and eventually I will need to adjust the PTO angle/height/etc. to work with taller wheels/tires.
TIA
   / Berta flail mower adjustments?? #2
It's pretty simple to change from the low setting to the high setting. I've done it a few times without a manual. Tracmaster has a parts breakdown on their website http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0CDsQFjAF&url=http%3A%2F%2Fwww.tracmaster.co.uk%2Fspare-parts%2Fdoc_download%2F480-flail-mower-attachment-berta.html&ei=lkiJVcScMsOryASQ34yACQ&usg=AFQjCNGU8yzfxv7-OYi1g8EDQTJ4jlSh7A&sig2=Yo6650BV59xN10LwrxHb3g&bvm=bv.96339352,d.aWw
The baffle is removed by removing the four lock nuts on top and to the rear of the shroud. The baffle comes out from underneath.
Adjusting the cutting height involves raising or lowering the roller. I find it easiest to do this by tipping the flail mower up on its side Remove the rear m8 bolts and loosen the front bolts with 13mm or 1/2" wrench wrenches. Swivel the roller up or down as wanted. You can get more height by moving the front bolts to the lower hole as well.
TMG-PSM30 30in Portable Sawmill (A42745)
TMG-PSM30 30in...
John Deere 702 (A44502)
John Deere 702...
2019 KENWORTH T880 (A45333)
2019 KENWORTH T880...
3pt Ditcher (A44502)
John Deere 4052R (A44501)
John Deere 4052R...
2015 WESTERN STAR 4900 SF (A45333)
2015 WESTERN STAR...
