berryman chem tool for 2 stroke?
   / berryman chem tool for 2 stroke? #1
2458n
Veteran Member
Can you use this product on a chainsaw to clean a carb? I was told yes by the factory but remain unconvinced. Has anyone done so?
   / berryman chem tool for 2 stroke? #2
Since it claims that is what it is for I would say it's worth a try. Have you tried Googling it to see if there are any positive or negative comments?
I have recently replaced the usual gas line and carb parts. The saw runs very well and starts easily all day once you get it started. It is like it loses it prime of gas after sitting over night. The new diaphram should help pull the gas thru. I guess I will follow your advice and Google it before gambling.
   / berryman chem tool for 2 stroke? #4
Does it have a primer bulb? If so I would replace that or check the lines in and out the primer bulbs go bad as well as the hoses fitted onto them
No primer bulb. The bad gas just eats everything. Maybe even my new carb parts that are now a year old.
2018 Ford Escape (A50324)
2018 Ford Escape...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
Toro Z Master Mower (A50322)
Toro Z Master...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
