Bercomac SSQA snowblower experiences
   / Bercomac SSQA snowblower experiences #1
oakhilltop
New Hampshire
Airens 18GT
I recently discovered the existence of the Bercomac SSQA snowblower .
I am not sure about the durability of it. Let me know if you have seen these. I'd like to hear what others have experienced. At the moment, it appears to me as an expensive gamble. It may be one of those you either love it or hate it thing. It would be a major bummer to buy one and during the first storm realize that it doesn't work well for me.
As I see it,
Pros:
Independent of tractor model/brand
Quickly attach and remove. It would be easy to put the bucket back on when needed.
Cons:
Appears to add 1 to 2 feet of length to the tractor. Less maneuverable
Have to make sure there is a supply of gas
Have to start another engine when going to clear snow..
   / Bercomac SSQA snowblower experiences #2
Tough to say, but here are a few observations.
- I see two 5 gal gas jugs, one on each side, with what look like suction tubes in them If that's the fuel supply, that strikes me a very boot-leg.
- The "screw" snow collectors look like think stamped metal like on low end snow blowers. On better machines they are steel bar shaped in the the spiral
- It appears to be a 3PH, combined with a SSQA to 3PH adapter plate. Not sure if that's good or bad.
I would want to talk to a few reference customers, and especially understand how it works in deep snow and heavy wet snow. Any snow blower works great in light fluffy stuff.
   / Bercomac SSQA snowblower experiences #3
My guess is you'd be $8k+ ahead just using the tractor & bucket for any snows that this wannabe might handle.
Now if you were in VA instead of NH.....😉
I wish I could just use the bucket, but it doesn't work on my driveway. There have been a couple of April storms that came after I removed the snowblower and put the bucket on, and the bucket was a PIA to use. I ended up getting the backup EGO walk behind snowblower out. That works, but is not fun on 400 feet of a very steep driveway. It's very difficult to angle the tractor towards the side to dump the bucket, and I don't want to go completely sideways on that incline.
I'm considering upgrading the tractor, and front mount snowblowers cause the most complications due to the proprietary nature of attaching them. Plus they are not near the top of the list of most users attachments. Kubota has an attachment system that appears to go on and off quickly. A few days ago, I tried out a Kubota B2301 and I just couldn't get comfortable with that forward/reverse pedal.
JD has a nice attachment system, but the JD price's are out of my range.
Other brands have more klunky systems. Often, the videos show the use of floor jacks under the tractor. But the price of the tractor is more in my range.
   / Bercomac SSQA snowblower experiences #5
22 HP for 54” blower sounds a little under powered for heavy snow. I also didn’t see the weight nor any dimensions so curious how much loader lift capacity you require along with rear ballast.
   / Bercomac SSQA snowblower experiences #6
I agree $8K for a snowblower only is not viable, when you can buy a tractor with a snowblower and loader for 15K or less, and there's several Kubota's listed on FB Marketplace for that in NH - here's the link. Log into Facebook
   / Bercomac SSQA snowblower experiences #7
   / Bercomac SSQA snowblower experiences #8
If this is for occasional use and 400 ft of driveway I would look real hard at simple 3 point mounted blower provided your tractor has 3 point and PTO. Simple, inexpensive and proven design that works along with can leave loader on tractor.
   / Bercomac SSQA snowblower experiences #9
What surface is your drive?
It sounds like traction is your problem.
I use chains on my SS and screw in studs in my tractor tires. The studs are in permanently and are miles better than nothing but don't equal chains.
With just a little portion of $8k you could have a set of "winter tires" permanently chained up with the best "ice chains" if you're not running on pavement.
I get my "stuff" from these guys in Tamworth NH if that's convenient to you. 👍
Our JD is 16 years old and as I said, in the winter, we need it to work. Other times of the year, it's ok if it takes some time to do a repair. I'm thinking that time can take its toll on o-rings, seals, etc an even though the 2305 has been very reliable so far, I might start seeing more issues. I'm trying to figure out if I'm being foolish about that but just don't have the experience with tractors. Plus, I would like to have a little more lift capacity etc.
I was not aware of the front pto systems. Thanks for the links. I wonder how long it takes to attach and remove the pto part of it.
2022 Club Car...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2011 New Holland L225 Skid Loader (A49251)
2011 New Holland...
2019 CATERPILLAR 313FL EXCAVATOR (A50458)
2019 CATERPILLAR...
2019 FREIGHTLINER CASCADIA DAY CAB (A48992)
2019 FREIGHTLINER...
2007 DELTA  GOOSENECK TRAILER (A48992)
2007 DELTA...
