Bent Rim 1430
   / Bent Rim 1430 #1
SELKIRK
Matagorda Tx
Power Trac 1430
After using my mini hoe to tear down a brick planter box I noticed that the back rear wheel was wobbling. Thinking that the wheel motor was loose I took the wheel off and checked. It all looked tight and ok, so I swapped wheels front to back. Found the problem, bent rim.
This is a new 1430 (20hours) could there be a defect in the rim to cause this failure. The work load was medium on level ground and I did not hit anything or put undue stress on the machine.
I will call PT on monday to see if falls under warranty issue or not.
If not is there any way to fix this rim?
Any one else having problems with the rims.
Terry
   / Bent Rim 1430 #2
Welcome to the pt forum. I can't recall anyone having problems with a bent rim on an almost new power trac. I would talk to Terry as you mentioned.
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
2022 John Deere 4066M Heavy Duty MFWD Tractor (A53342)
2022 John Deere...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2012 KENWORTH T 7 DOUBLE BUNK SLEEPER (A52576)
2012 KENWORTH T 7...
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
