Bent quick attach
   / Bent quick attach #1
coolconnection
Ohio
Massey Ferguson GC1723
Has anyone on here ever looked at their quick attach on their tractor and does it look flat? I have only 30 hours on my pt425 and I took off the mower the other day and I noticed the quick attach plate on the tractor is bent a little bit. That part that connects to attachments. I haven't abused it or anything like that but the steel plate is bent slightly at the top. I bet 20 hours on the tractor is just from mowing so unless the mower deck gained weight I can't figure out how it happened. Is anybody else's steel plate bent slightly and if so what did you do about it?
   / Bent quick attach #2
Hmm, It really requires a picture to see to what degree its "bent", PT's are more or less hand built machines, and if you scrutinize them enough you are bound to find many imperfections. having said that, mine is fairly straight, although not perfectly flat.
   / Bent quick attach #3
My QA, on the tractors side (the flat plate that fits in the implement) is bent a bit at the corners. Jamming corners of buckets into stumps tends to twist the system.
   / Bent quick attach #4
Hmmm. When I mow I use the dump/curl to make sure the mower carriage is centered, then push the joystick into float so the weight of the tractor never gets put on the mower deck.
I've beat the heck out of my quick attach with the buckets and forks. There is a little wear, but it is still flat and straight.
   / Bent quick attach #5
My QA plate is still flat, as best I can tell, but I've tweaked my lift arms where the QA plate attaches to the point that a bucket doesn't sit exactly flat...
On my last trip to TN, my son was sawing up downed pines from one of last winter's storms, while I was following behind, scooping them up and carrying them to the brush pile with the grapple bucket. Well, I had the bucket curled all the way down with the teeth just above the surface and drove up to this 15' long chunk of pine about 8" through. Rather than stop and pick it up, I tried to just scoop it up and continue on...
Come to find out, one end was still attached to the stump. I immediately jerked to a stop, with the PT puckered at an angle... and yelled for him to come saw it off at the stump. But not before this long lever with the force of PT in motion tweaked my lift arms.
With 48" LM bucket, one side is now about an inch higher than the other...
I'm not sure how I'm going to fix this faux pas, nor do I have enough time on the PT since to see if it's something that I can just learn to live with. My initial impression is that I need to deal with it, just not sure how. May try to rig a long lever on the opposite side and see if I can either bend it back or tweak it to match... :eek:
   / Bent quick attach #6
Kent,
If you have something buried in the ground, or perhaps you can bury a large flat plate in the ground with a 3/8 in lifting chain. Then lower your arms about 10 in off the ground, and attach the higher or the arms to the chain. Then place a hydraulic jack under the other arm and jack it up and adjust the height to your satisfaction. Could also use a torch on the center supports.
   / Bent quick attach #7
...Well, I had the bucket curled all the way down with the teeth just above the surface and drove up to this 15' long chunk of pine about 8" through. Rather than stop and pick it up, I tried to just scoop it up and continue on...
Yeah. I've noticed that with the implement dumped all the way down there is very, very little power available to bring it back up. If you curl it up a couple inches, then it has tons of power. Must be something about the leverage point at that end of the dump cycle. I can see how you could do some damage. I wonder where your bend is? The arms or maybe the mounts for the arms? If you still have full range of motion, you may just want to live with it. Unless, of course, you want to be able to do stuff that requires level operation.
   / Bent quick attach #8
Just eyeballing it, it looks like it may be tweaked just a little bit in two places. Theres's a slight bow visbile up near where the pivot is for the bucket dump. Then there's a slight "wrinkle" just above the bolt that holds the QA plate to the arms. Both would seem to be indications that something shifted...
I don't know if you've ever twisted cold metal, but sometimes it will look wrinkled, instead of a smooth bend like when it's hot. That's the way it looks down next to the QA plate.
Neither place looks all that bad on its own, but I think one compounds the other...
   / Bent quick attach
Thanks for all the replies. It functions just fine but I keep thinking if it was that way when I bought it or did I do it. I just wondered if anybody else had this same issue. I can live with it but I mow a steep incline so I just lift the deck up, drive up to it,set the deck down gently and back up. Repeating this process many times. It is 300 feet long so what ever a 60 inch deck will do.
Thanks again.
   / Bent quick attach #10
Thanks again.
Do you have the mini hoe? I have bent two quick attach plates over the years using the mini hoe. It occures when I hook up and do not realize that one pin is not all the way down and then put pressure on the hoe.
PJ
Payment Terms (MUST READ) (A50775)
Payment Terms...
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
7021 (A50322)
7021 (A50322)
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
