JSanders10
On my 6' bushhog rotary cutter, I must have raised the cutter to high with the 3pt lift slightly bending the PTO shaft... it just won't slide off like it should.
I assume this because I can't get the tractor end of the PTO shaft removed from the PTO spline (has the quick disconnect push pin).
The hammering area is a bit limited, but I know I can keep at it and finally get it off.
Other ideas to back the PTO shaft off the tractor PTO?
After that, should I just remove the safety casing and try to un-bend the shaft, with additional hammering?
