Bent Hydraulic Cylinders - Now what?
   / Bent Hydraulic Cylinders - Now what? #1
Doug_D
Kubota M7040
Hey all,
I have managed to bend the two cylinders on my 70HP kubota for the front bucket curl control. Dealer wants $650 for each cylinder or $250 for just the rams and $60-$70 for the pack kit. Trying to figure out which way I should go or if there is a better way.
Dealer is a little concerned the cylinder may not be rebuildable. Is there a quick way to check?
I was back grading and heard a loud pop and knew something happened. I did have the bucket rolled pretty far out and I must have hit something. I stopped the tractor and got out and looked things over, but did not see anything. I did not notice any problems until tried to roll the bucket back down (up was fine) and go back to work. When I finally got the rams to extend, I could see the bow. It's not bad, but it will prevent the bucket from rolling down. It is a slight bend...any chance of bending them back?
This could not of happened at a worst time for me. Any help would be great.
   / Bent Hydraulic Cylinders - Now what? #2
Pictures!?
Bending the cylinders back sounds like a bad idea.
$650 sounds pretty steep for those cylinders. I'll bet you can buy a compatible part from Surplus Center and a can of nice orange paint for a lot less than $650 a piece. Unless there's something super special about those kubota cylinders, I'd be looking for a replacement somewhere else.
   / Bent Hydraulic Cylinders - Now what? #3
Take them to a hydro shop. They can straighten them, or replace the rod or the entire cylinder
Not a big deal.
   / Bent Hydraulic Cylinders - Now what? #4
Hey all,
I just bought a pair of double-acting 2" dia x 20" stroke, 1" dia shaft 3000 psi cylinders with swivel ends from Surplus Center for about $145 each for one of my projects. You should be able to find a pair of cylinders from SC that will fix your problem for under $400. Tell the dealer to shove it.
Thanks for the help guys. I will post pictures tonight when I get home.
   / Bent Hydraulic Cylinders - Now what? #6
If it is indeed a slight bend, you can straighten them out.
If severe or kinked, replace them. My wife's loader cylinders bent because the dump/curl cylinders were not located properly. I repositioned the cylinder attachments and also straightened out the slight bend in the rods. I wrote a thread about it with lots of photos showing what I had to do. It started with trying to get more curl for her Jinma than factory when I noticed the cylinder rods were bent. Here is the thread if you want to read about it starting with post #2. The following posts show how I straightened them out and now they are fine 130 hrs later still no problems with them.
Add more Bucket Curl to Jinma 284
Below are some photos of the bend in the rod and how I straightened them out and then they are straight again.
I flipped the rod around 180 degrees and used a rebar wedge and pipe between the rod and fel arm. I used the tractor hydraulics to do the bending back to straight. Last photo shows the rod straight again.
If yours are only slightly bent, you can do the same thing yourself.
   / Bent Hydraulic Cylinders - Now what? #7
If your thinking you might have to bite the bullet and get new ones, then first I'd try and bend them back like 3RRL did, you've got nothing to loose.
I should think a tractor that size could handle what ever you throw at it but I've heard that back blading with curl so far out that the edge is cutting, will do that type of damage.
Good luck, JB.
   / Bent Hydraulic Cylinders - Now what? #8
G'day as mentioned before it is possile to straighten rods that are bowed not bent they will not have quite the same strength they would have originally but they are usually up to the task at hand. I have straightened them before without any dramas if you use the rebar technique you do run the risk of marking the rod though and that is not good as it will damage the gland seal when you use it causing it to leak:( The best way is to strip rams and press in hyd press i will tell you the same thing i tell all my customers with FELs fitted to their tractors that a dozer doesn't have rubber wheels:D Best of luck if you are going to strip though good idea to replace seals.
Jon
WOW Guys! Thanks for the help.
Rob; I am going to try what you suggested. I really think my bow is less than your's pictured. Sounds like you have considerable skill with hydraulics. Hope I am up to the challenge :)
I will post pictures this evening.
   / Bent Hydraulic Cylinders - Now what? #10
Thanks Doug, not much experience really just common sense and a little mechanical ability.:)
Like banjodunn said, I would use a leather shield over the rebar or pipe next time. Fortunately, mine were not scored though. When you flip the rods 180, re-pin them into your cylinder front mount or bucket. You might have to use a crow bar to get the wedge under the bend spot since it will be down towards the fel arm. Pry it up gently away from the fel arm. Just keep repositioning the wedge (bar) and extend the cylinder until the rod takes the bend back to original straight. Use your dump on the fel (extend the cylinder) and go slightly past straight when bending it back and check it. If not straight enough, do it again with a little more bend at the wedge. If yours are not bent as much as mine were, it should work for you. If your bend is as slight as you say, chances are your seals are still OK too. You will know if they leak.
Looking forward to the photos ... take some action shots of how you do it too.
Rob-
eXmark Quest 52 in. Zero-Turn Lawn Mower (A53117)
eXmark Quest 52...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
Metal Pelican Lawn Art (A51694)
Metal Pelican Lawn...
2013 Mahindra MPOWER 85P 4WD Tractor (A53117)
2013 Mahindra...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
