Bent front wheel
   / Bent front wheel #1
MESSMAKER
Veteran Member
Bluegrass,KY
DK4710SE
I have a ct225 and hit a curb with the front tire the other day. I was running the tire a bit low on air and it bent the outside rim a bit. It now has a slow leak. Can I straighten it or am I going to be looking for a new wheel?Anybody know what a new wheel cost?
   / Bent front wheel #2
If the bend is only in the bead area you can dismount the tire and hammer it back down. I've done it a few times on car and truck rims for friends that also hit a curb and bent the bead lip. (Though, I think their bent rims were alcohol related.) Once hammered straight I remounted and balanced the assembly and checked for leaks. It is more difficult if the rim is bent toward the hub area and may need replacing.
   / Bent front wheel
I don't think the bead is bent. The lip turns in about 3/16 and I think it may be pushing the tire away from the rim ever so slightly.
   / Bent front wheel #4
Take the tire to your favorite tire shop and have them straighten the rim and seal the bead.:thumbsup:
   / Bent front wheel #5
If the rim can't be straightened enough to seal the tire, wouldn't it be cheaper/faster to just put a tube in the tire? I ruined a rear tire on my CT235,(puncture in the sidewall) and the tire shop was drooling, wanting to sell me a tire. I asked him about tubing the tire. He said it didn't even enter his mind. Yeah right. Tractor running great with the tube. JP
   / Bent front wheel
Putting a tube in can be a problem if you deal with thorns, as I do. You can use Slime and plug the tire if needed. Does not work well with a tube.
   / Bent front wheel #7
Yellow Slime works with a tube.
   / Bent front wheel #8
The front wheels are NOT expensive.
Long story: I bought my tractor used, and someone had put a narrow front rim on with the original R4 tire. Tire was cracking because of the wrong rim size, and eventually leaked bad. Bought 2 new front tires, and ordered a rim from Bobcat (expecting it to be very expensive). I was pleasantly surprised. I don't have my receipt in front of me, but it was on the order of $50.
   / Bent front wheel #9
You may be surprised that most of the Bobcat CT parts have been marked down to liquidate surplus inventory. :)
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
2021 Snake River 14ft T/A Dump Trailer (A49461)
2021 Snake River...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2015 DODGE RAM...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2011 Cadillac SRX LUXURY (A50324)
2011 Cadillac SRX...
