Alan7s
When we got the cylinders out of our Terramite - the ones that swing the hoe from side to side - we noticed one had a slight bend in the shaft. It seemed to work OK but leaks fluid so we're hoping to rebuild it. Is it OK to rebuild with new seals and use as is, or should we replace it? New to this, and not sure if this is common for swing cylinders and will just happen again or if it needs replacing. Also any thoughts about what causes this appreciated. Thanks
