bent adjusting lift arm on Bobcat 230
   / bent adjusting lift arm on Bobcat 230 #1
george88
Howdy,
Bent the screw portion on the right lift arm. Has anyone done this and is there a quick fix? Is the screw portion available over the counter/aftermarket that could be replaced? Can it be straightened?
Looked at TSC today and they have one potentially that could fit, but not the identical, would adjust by hand and the top connector part would have to be shimmed with spacers, believe it is a ford type.
geo,
   / bent adjusting lift arm on Bobcat 230 #2
The individual parts of the adjustable lift link are called out in Bobcat parts book, have no idea of availablity though.
   / bent adjusting lift arm on Bobcat 230 #3
I have no doubt that you can get the parts to repair or replace what is needed. Probably won't even cost that much. Do you need to replace the entire unit, or just a part of it? What did you do to bend it anyway? :confused:
1999 CATERPILLAR TH82 TELESCOPIC FORKLIFT (A51242)
1999 CATERPILLAR...
2015 BMW 3 Sedan (A50324)
2015 BMW 3 Sedan...
Kubota SVL95-2 High Flow Cab Skid Steer (A52128)
Kubota SVL95-2...
2012 John Deere 7280R MFWD Tractor (A52128)
2012 John Deere...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2016 FORD F450 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F450...
