Bent 3pt lift arm
   / Bent 3pt lift arm #1
jray
CS Colorado
Shibaura 4x4 SD1840
Well I was working on building a parking area in front of my House today with my box blade. I was using the BB going backwards to push some dirt around and gradw down a hill. Well I made some adjustments for the vertical position of the blade and continued working. Well when I stopped for the day I was going to adjust the BB back to a level position and thats when I noticed the right side lifting arm was bent down and to the outside of the tractor. I was wondering if someone has encountered this problem before, were you able to remove the bar and have it pressed back straight or did you just replace considering any unknown stresses on the part in question. Any responces are appreciated.. Jray
   / Bent 3pt lift arm #2
You didn't say what kind of tractor you have but on my Ford 1710 it is just a couple of pins and slide the new one on.
Check out a nearby TSC store or see your dealer. It shouldn't be to bad of a fix
Good Luck
Bartman
   / Bent 3pt lift arm
bartman its a shibaura the sister model to I believe the ford 1500 ?? Anyway thats what I was thinking it just has a snap ring holding it in place hopfully it will slide off pretty easy with out any persuasion. I just bought used man I fell stupid for not noticing it sooner. I was pulling the Brushhog yesterday and it was pulling crooked seems like this is probably why. Anyway thanks alot for your help Jray
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
2002 Enclosed Trailer (A52377)
2002 Enclosed...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
PALLETS OF HEAVYEQUIPMENT (A53843)
PALLETS OF...
Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
Peterbilt National...
2009 Freightliner M2 106 Ambulance (A51692)
2009 Freightliner...
