BENDING MOWER WHEELS AND YOLKS
   / BENDING MOWER WHEELS AND YOLKS #1
albert
Bronze Member
middle Tn
Toolcat D
Using a 72" finish mower with a 5600 Toolcat. Mowing irregular terrain with a lot of roots. Problem is that I keep bending the wheels and wheel yolks (I've gone thru 4 and am being as careful as I can). Anybody encountered this problem? If so, any solution? Bobcat does not make a beefier wheel and yolk. Anybody know of an aftermarket source for something beefier?
   / BENDING MOWER WHEELS AND YOLKS #2
Got any parts for sale? I may be able to use them. If you take pics
and post up I'll see if I can use them...
I have been lookin' for a deal on swevilin' yoke type wheels .
   / BENDING MOWER WHEELS AND YOLKS #3
have been using a 72 inch for over a year and have not had any problem, how old is your mower? I know they made some changes a year ago or so.
Artisan: nothing for sale. Toy 1: mower is 4 years old.
   / BENDING MOWER WHEELS AND YOLKS #5
Look at how far the Bobtach is tilted out. If too far it will push against the mower when going over a rise, it not tilted far enough it will pull mower off the ground going over a hill. May also try running lift in float allowing the mower to push the lift arm up when it gets in a bind.
   / BENDING MOWER WHEELS AND YOLKS #6
I do not run my machine in float with the mower, the mower has it's own float if you allow the cable to be relaxed it will act as if in float.
I think the new mowers have beefer yolks.
   / BENDING MOWER WHEELS AND YOLKS #7
I recently bought a 72" finish mower for my toolcat. I tried different things and settled on float for irregular terrain. I'm using it where I would normally use my brushcat on my Bobcat skid. I also slowed my travel speed down some and so far, so good on the rough terrain. I have stumps and rocks to avoid or mow over and the float setting seems to help.
2007 Pace American JT716TA2 20ft T/A Enclosed Trailer (A49461)
2007 Pace American...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Lowboy Trailer (A49461)
2019 Fontaine...
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2008 CATERPILLAR D6K LGP PIPE LAYER (A50854)
2008 CATERPILLAR...
