Bench testing a coil, Stihl FS 55R
   / Bench testing a coil, Stihl FS 55R #1
Paddy
Veteran Member
Bloomington, IN
Kubota, G5200, KAMA 454
Can you bench test a weed wacker coil? I first removed the kill switch. The switch shorted the spade terminal to the iron core. Replaced the plug as well. Even held the spark plug while pulling!
What should the resistance be from;
spark plug wire to, terminal?
spark plug wire to iron core?
terminal to iron core?
Some say you can but my local repair shop said it takes some special equipment.
Patrick T
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52705)
KNOW BEFORE YOU...
PALLETS OF HEAVYEQUIPMENT (A53843)
PALLETS OF...
2013 W-W TRAILER ENCLOSED TRAILED (A53843)
2013 W-W TRAILER...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
