Belt Tension
   / Belt Tension #1
retired007
New Holland 3930 Kobota Zd21 Mule 4010 New HollandTZ25DA
How do you tell if you have your belt too tight on a finish mower? I noticed that I had quite a bit of heat (hot to touch) in gear box and pulley's on the mower after mowing awhile. This is a used mower that I just bought and it seems to have more heat than the old mower I had. Any help or advice would be helpful and appreciated.
   / Belt Tension #3
Most mowers use a spring tensioner. As long as it is not bottomed out and has travel both directions, the spring dictates the tension and there is usually no adjustment for making it tighter or looser.
On applications that dont have a tensioner (usually not mowers) belt manufactures publish specs. Something like 1/2" flex over a certain distance. And they also make fancy gadgets for checking tension as well.
   / Belt Tension #4
If there is belt slip, heat in pulleys will develop very quickly. Try this ... Start the mower drive and let it run a couple minutes no load. Then cut some heavy thick grass, applying hi load for about a hundred feet. Quickly stop the machine and check the pulleys. If they are barely warm youre good to go. If they are uncomfortably warm inspect the pulleys for wear and tighten the belt. If the hi heat persists replace the belt ... and the pulleys [if worn].
larry
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2019 JOHN DEERE 5090M LOT NUMBER 93 (A53084)
2019 JOHN DEERE...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646718 (A51572)
2013 Dodge Charger...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
