Belt squealing
   / Belt squealing #1
Kodiak45
SC
long 2460 - belarus 250 - JD 4230 - Kioti DK40SE
The belt on my dk40 will squeal on start up and go away after 30 sec or so. It will do this whether the engine is hot or cold. Any idea what would cause this and what to look at first for diagnosis? It doesn't do it every time, but at least 7 out of 10 starts.
   / Belt squealing #2
First, is the belt tension correct? A loose belt will squeal on start up.
Second, As a belt ages it can stretch and get loose. Also a loose belt can get glazed from slipping causing a squeal.
Third, if the belt is good and adjusted correctly the squeal could be a bearing in the water pump or alternator that is starting to go.
   / Belt squealing #3
It's the alternator belt, it creates more drag while producing additional amps to replace the charge used in starting, that's why it goes away once the load decreases. Belts shouldn't be run any tighter than necessary as it's hard on bearings, but they shouldn't be allowed to slip, as that can glaze them and lead to more slippage, etc.
   / Belt squealing #4
Only two likely issues - adjustment or glazed belt. Tighten the belt. Replace the belt if it still squeals.
   / Belt squealing
I tightened it a good bit and we'll see how that does. I tightened it to about 1" or so of deflection. Hope that resolves this annoying issue
   / Belt squealing
NO just retighten then if still squeals get a new belt
I think that's best. I tried dressing and it was only a temporary fix if it helped at all
   / Belt squealing #9
Before starting it, spray a bit of water on the belt. Once you start it, see if the squealing is still there, or not.
If still there, it,s a bearing, If it goes away, it,s the belt has been glazed.
   / Belt squealing #10
Working on the tractors is just as much fun as digging :laughing:
2012 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A45333)
2012 KENWORTH T800...
2007 KENWORTH W900 MIXER TRUCK (A45046)
2007 KENWORTH W900...
2015 PETERBILT 389 FLAT TOP SLEEPER (A45333)
2015 PETERBILT 389...
2019 John Deere 1023E Tractor (A44391)
2019 John Deere...
2020 Ford F-150 XL (A44501)
2020 Ford F-150 XL...
2014 MACK CXU (PINNACLE) (A45046)
2014 MACK CXU...
