Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,993
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I was out cutting a field yesterday. I noticed a bit of a burnt smell. Pretty much the exact smell if you are smoking a drive belt on a pully.
I have noticed lately that the tractor keeps running near hot. Hmmm.... do I have water/antifreeze mix in radiator? Yep. Is radiator unobstructed? Yep.
Now, I DID recently rebuild all three hydraulic motors for the flexwing mower as well as the hydraulic pump to power them. EACH one of them was much stiffer to turn after rebuild than before (which I'm attributing to tighter sealing now)
Other than that, nothing has changed. I historically cut the big hill in 3rd gear going up/down....and sometimes in 4th gear up/down. Yesterday I was in 2nd gear or 3rd gear with T/A engaged, slowing me down a bit.
That said, the grass was waist high so I know that was also adding a strain.....BUT..... I go back to every now & then catching a wiff of that burnt smell again (as in I smelled it again)
I'm beginning to wonder/suspect that my water pump might be starting to freeze up on me, hence the burnt belt smell and higher temps. I might add that when I'm going home, engine RPM's are down, the engine will easily cool down to or just below (on the cool side) of the first mark on the gauge.
Oh.... and the other day when I was cutting a different field, I was going in/out of T/A and during one of those lurches, I DID notice a puff of smoke from the front of the engine, along with again, that burnt belt smell. So I'm thinking that the pump is creating some resistance and when the RPM's jumped up it spun the belt a bit, creating some smoke.
Thoughts?
(no, I've not yet had time to dig into it and take anything apart)
Thoughts?
