belt pulley
   / belt pulley #1
professor
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
I have a friend who bought an antique grist mill that is operated by a belt. He has a Kubota and was wondering if Kubota built a belt pulley that attaches to the pto. I don't know model of tractor. /forums/images/graemlins/confused.gif
   / belt pulley #2
I've never seen a belt pulley on the 3 pt. Usually on the side of tractors, though some had one on top of the differential facing rearward.
I suppose you could make one, using a gearbox/pto/3pt. I'd think it would be easier to modify the grist mill (which if it's antique, you might not want to do) by taking the pulley off of it and installing a PTO shaft so you could hook it direct to the tractor.
I've seen guys hook up for belt operations, and it's not a simple process. Things have to be pretty straight or the belt goes off the pulley.
If you hook up a PTO shaft, be sure to either anchor both machines or better yet, hook them together. You wouldn't want them to dance apart and have the PTO shaft flopping about whacking stuff.
Good luck,
Ron
   / belt pulley
I remember the belt pulleys too well. Since I am over 50 I can remember several pieces of equipment that we used on the farm. We used an Oliver88 to power a grist mill, cut-off saw, saw mill and silage blower.
I bougth a grey market NH 3930 and the operators manual had a picture of a belt pulley attached to the pto. We owned an Oliver55 that the belt pulley attached to the pto. Several antique and vintage tractors had rear pulleys such as the JD M, 40, LA etc, International cub and A.
TRUCKING INFO (A50775)
2019 Nissan Versa Sedan (A51694)
2019 Nissan Versa...
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
