Belt on finish mower slipping?
   / Belt on finish mower slipping? #1
Arc weld
Veteran Member
Edmonton, Alberta
MF 135
Can a belt loose it's tension/stretch just because it's old? I have Sicma 72" finish mower that used to work to work great at my old place but I haven't used it for quite a few years. I bought the mower new. Now it seems that even if I tighten the belt it just stretches and starts slipping again. It doesn't even make the tractor work (MF 135 diesel). The other thought is the sides of the belt that grip are just worn too much to properly grip the pulley. The belt seems to fit fairly deep in the pulleys. Maybe new belts is all I need? Any insight would be much appreciated.
   / Belt on finish mower slipping? #2
Yep, belts can stretch to the point where they're not tight enough, and can also wear so they don't sit properly in the pulley as you have noticed on yours. I'd bet that a new belt will fix you right up.
1264 (A50490)
1264 (A50490)
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
2019 TRITON TRAILER ALLMAND MAXI LITE 45 GENERATOR (A52472)
2019 TRITON...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
