Belly mower for B7100 HST
   / Belly mower for B7100 HST #1
kcaj
My Kobota Dealer tells me there are no mid mount mowers available for my 1981 B7100 HST tractor . Can anyone confirm this or tell me where I might find a 60" mower.
   / Belly mower for B7100 HST #2
Any chance you might have the front pto clutch on your tractor now?
I have the mid mount PTO
   / Belly mower for B7100 HST #4
I have a Kubota RCB60 60" mid mount mower listed in the classifieds. The deck came off of a 1982-3 B8200. The B8200 had a front mount PTO, but the gearbox on the deck can be turned around. I know that the deck can be installed on a B7200 and it may fit the 7100 also.
Take a look at the ad and contact me if you are interested in the deck.
   / Belly mower for B7100 HST #5
A few comments:
(1) In general, complete unit assemblies (such as mid-mowers and front end loaders) are not available for older Kubota tractors. I have never had any problems purchasing individual parts for the tractor or its attachments.
(2) I may be wrong, but I thought that it was around 1984 or 1985 when the Kubota came out with the B7100HST. The B7100 gear drive production started in the mid-late 1970s.
(3) At some point in time the wheel base on the B7100 got extended. This is supposedly why the front end loader for the 1990s model will not work on the older gear drives. This extension affects the mid-mower availability. I was told that the extended B7100 chassis came in the mid-1980s with the introduction of the HST models.
(4) The older gear drive B7100s used a front PTO with electic clutch and only had a 48" mid mower available; I would not recommend anything larger than 48" with the front-PTO on a B7100. The 1990s B7100HSD had both 54" and 60" mid-mowers to mate up the the mid-PTO. Based upon your description it appears that the early B7100HSTs had a mid-PTO as well, but I don't know if it used the same mid-mowers as the 1990s B7100. I have seen several of the mid-mowers for the 1990s B7100HSD for sale at various places including the Equipment Trader portion of www.traderonline.com.
Hope this helps,
Kelvin
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
Miller Welder (A51691)
12in Backhoe Bucket (A52748)
12in Backhoe...
3 pt Rolling Basket & Harrow (A50514)
3 pt Rolling...
