Mowing Belly Mower for 186D
   / Belly Mower for 186D #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
I may not be able to repair the top link to my 3PH. (see Top plate Woes thread) If not, could I still ise a belly mower? What would fit, and where can I find one?
I realize that it would have to be driven by the rear pto, and mine has tho speeds, 540 and 1000.
   / Belly Mower for 186D #2
Mike,
Regarding your attempt to fix your top link attachpoint, have you also considered drilling and tapping two new bolt holes inward of the two rear facing broken holes? The solution that you have come up with I think is a good one, but you could also use all the added strength you could get. It would also be ashame not to use this valuable flat area that could still add a lot of strength to the overall solution. If this was already recommended, I'm sorry I missed it Or, if something has already been discussed that invalidates this as part of the solution.....sorry I missed that also....
Good Luck
Russ
   / Belly Mower for 186D #3
If I'm not mistaken, the OEM belly mower for the YM186D was a 5' Woods run from an electric clutch on the front of the tractor. If it is like the YMM45 I have (original for the YM135, YM155, YM155D) the lift mechanism uses cables attached to the 3pt upper arms and some pulleys mounted where the 3pt lower lift arms attach to the transmission/axle housing. The cables ran from the upper lift arms around the pulleys, around pulleys on the deck, and back to the tractor above the deck.
So the answer to your question is YES, you should still be able to use a belly mower. I don't know if Woods still makes the model for your YM186D or not. Try Len Sheaffer.
Sheaffers Town and Country Tractors
320 Palmyra Rd
Dixon, IL 61021
sheaftractor@coiinc.com
815-284-3226
Greg
   / Belly Mower for 186D #4
Here is a web page that has pictures and spec. for Woods belly mowers to fit the 186.<A target="_blank" HREF=http://www.tractorbuddies.com/>Woods mowers</A> I thought I remember Len saying that Woods didn't make the mounting kit anymore. I also thought I remember Len saying he had some in stock but that was a while ago.
Chris
   / Belly Mower for 186D #5
I have seen a 186D which had a Woods mid mount mower that ran off a big pulley on the PTO and the deck raised on cables that ran back to the 3 point lift arms.
Chris
   / Belly Mower for 186D #6
I have 1 new belly mower for the YM186 in stock. I bought the last 3 they made.
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2006 Husqvarna YTH2148B Riding Mower (A51694)
2006 Husqvarna...
