Belly Blade
   / Belly Blade #1
rabcon
NY
312B , 307SB Cat, 450G Deere, Kubota MX5200 825i Gator
Has any buddy had a chance to see or use the belly blade by grouser.com ? It looks like a nice toy but costly !! (High $9000.)
   / Belly Blade #2
Never heard of it, but mid mount blades are the absolute best bet for making and grading driveways since it eliminates a lot of the "bounce" effect you get when you hit a bump and the blade is a couple feet out in front or back of the tractor. The big road graders are all set up with mid blades.
BTW, welcome to board!
   / Belly Blade #3
The short wheelbase on a tractor would make it difficult to achieve the same results as a motor grader. The long wheelbase on a grader will let the front tires travel over a fairly large bump or dip without changing the height of the blade much. The long distance between the blade and the front tires on a grader will give you time to change the height of the blade when you see a dip or coming.
When the front tires on a short wheelbase tractor travel over a bump or dip, the blade would rise or fall about the same amount. When the front tires on a tractor went over a bump or dip, the blade would be over it before you could react.
For rough work, the belly blade would be ok, but not for finish work.
When finish blading with a grader, we get down to the hundreth of a foot. Sometimes just scraping the blue paint off the top of a hub stake.
1982 S&S FLATBED (A52472)
1982 S&S FLATBED...
RHINO X1406 LOT NUMBER 64 (A53084)
RHINO X1406 LOT...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2019 DODGE RAM 3500 (A52472)
2019 DODGE RAM...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
