Bell Housing recall
   / Bell Housing recall #1
stobswan
I purchased a D model TC midsummer and have 53 hrs. on it. Recently when hooking up a snowblower I had difficulty connecting the plug ins. When I started up the rotor would not turn and it was spilling Hyd. fluid. The dealer could not find a hyd. leak, but noted a problem with ice not allowing complete attachment and recommended using a torch to heat the plug in in ice conditions. However in inspecting the machine he found a shredde belt and noted a maching problem in the bell housing and pulley alignment which Bobcat was furnishing a factory recall and replacement but have not notified owners. My neighbor who purchased a TC at the same time brought his machine over and it also needs the housiing replaced.
I thank the contributors of this forum for all the useful info and support.
   / Bell Housing recall #2
I don't have a Toolcat but I thank you for letting everyone else on here know of this problem.
   / Bell Housing recall #3
i think bobcat has been good about dealing with this issue. bad alignment between the drive motor and rex roth pump under load - either a casting or idler pully issue.
   / Bell Housing recall #4
Heating the plug with a torch? I hope he wasn't referring to the electrical plug...the plug guts will melt. I recommend a Harbor Freight heat gun for defrosting hyd couplers and roasting the occasional marshmallow when a campfire isn't available. A hair dryer will help an iced-up electrical connector with much less risk of a meltdown. The electrical connector can also use some contact lube/cleaner on occasion when in icy conditions. Water/ice just seem to like to collect there on my TC.
My Bobcat dealer has been forthright in discussing the casting/alignment problem.
   / Bell Housing recall #5
I have 4 attachments that utilize the front hydraulics and the blower gives me the most problems. I attribute it to being cold so the pressure relief is harder to push in and ice buildup that I don't always notice. I've never had it leak once I get it connected though. I always keep a rag in the cab to wipe off the couplers before I connect them.
dsb
   / Bell Housing recall #6
My mechanic called today requesting I bring my machine in for the Bell housing warranty . He had one other unit that he has already done. Great that Bobcat is taking care of this .
John Deere 918 Flex Head (A50774)
John Deere 918...
UNUSED FUTURE SKID STEER HYD BREAKER (A51244)
UNUSED FUTURE SKID...
John Deere 335 Round Baler (4ftx4ft) (A52128)
John Deere 335...
2015 Jeep Renegade (A50324)
2015 Jeep Renegade...
John Deere 920 Platform (A50514)
John Deere 920...
2011 Ford F-150 Platinum 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
