Belarus 250AS
   / Belarus 250AS #1
Sam Quint
Belarus 250AS
I just replaced the fuel filters on my tractor. I pulled the decompression lever and turned off the hydraulic pump to lessen the load while I bled the fuel system.
I finally got it started but I can't raise the bucket because the hydraulics stopped working. I moved the pump lever a few times and tried it in both positions. No luck. The lever gets hung up sometimes in between on and off. Not sure if that's part of the problem or just inherent of this machine.
The manual says to check the bypass valve and the pressure relief valve.
Anyone know where these two valves are located?
Sam
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
1043 (A50459)
1043 (A50459)
