bobtriump
I have a 1985 Belarus 250as. It has been sitting for over a year and when I went to start it the Engine wouldn't turn over. It was running perfectly fine the last time I used it over a year ago. After pulling out the starter which is good I tried turning the engine over with a 3/4 breaker bar on the front bolt of the crank and a breaker bar on the flywheel, but no good. Next, I removed the injectors and put Marvel mystery oil down into the cylinders along with Kerosine, but again no good. I also have the decompression bar pulled out. Does anyone have any ideas on how to get around this problem. Are there additional things that I could check? Any ideas would be greatly appreciated.
