Snowblower Belarus 250 tractor with Snowblower ????
   / Belarus 250 tractor with Snowblower ???? #1
Brandy McThunder
Does anybody out there have a belarus 250 tractor with a 60 inch 3 point hitch snowblower if so id like to know how it works before i buy a 60 inch 3 point hitch snowblower for my belarus 250 tractor??????
CAN YOU HELP ME?:confused:
   / Belarus 250 tractor with Snowblower ???? #2
I used to run a 72" blower on a 250A Belarus. The 250A wasn't a very good tractor for a rear snowblower for 2 reasons:
- PTO was transmission driven (not live).
- reverse gears were waaaay too fast, especially without live PTO.
It would move a lot of snow and fast as long as I could adjust the height (on the first pass and at the end of each blind run) and/or the width of cut fast enough to keep the chute from clogging, but I seemed to spend a lot of time digging out the clogged chute, especially in wet snow. Also, because reverse was so fast, it was hairy trying to steer around obstacles :eek:, sometimes having to stop to avoid hitting something and so clogging the chute. :mad:.
I now use the same old blower on a much smaller tractor (really too small for the blower) with live PTO and HST....it's a whole other world, no more clogged chutes. :D:D
You might have better luck with a 60" than I did with a 72", I don't know. The 250 has tons of power to handle it, it's just way too fast in reverse, especially without a live PTO.
Thanks for the advice :)
John Deere 825I Gator (RUNS) (A50774)
John Deere 825I...
2016 Ford Fusion SE AWD Sedan (A50324)
2016 Ford Fusion...
20' Inline Feed Bunk (A50515)
20' Inline Feed...
(4) Split Suitcase Weights (A50515)
(4) Split Suitcase...
2017 Dodge Caravan Van (A50324)
2017 Dodge Caravan...
