Belarus 2011 Hydro system uses engine oil ?
   / Belarus 2011 Hydro system uses engine oil ? #1
ourfarm
Hi New guy here.
I have had a Belarus 2011 for a few years.
I have not changed the hydro fluid and was looking
in the manual. The manual states that regular engine
oil is used for the hydro system.
Is this normal ?
Ourfarm
   / Belarus 2011 Hydro system uses engine oil ? #2
If you have an original manual for that tractor, and it specifies motor oil, then that is normal for that tractor. Case and New Holland skidloaders have used 10w-30 motor oil in their hydraulic/hydrostatic systems for years. Remember, you have an unsophisticated machine designed for use in adverse climates with the barest of product support.
   / Belarus 2011 Hydro system uses engine oil ? #3
Yes, this is normal. My FIAT tractor use motor oil in hyd/tranny too. Later models were filled with hydro/trans universal oil, so you can fill it with it too.
   / Belarus 2011 Hydro system uses engine oil ? #4
My Belarus 420AN used engine oil in the hydraulic system (10w30 or straight 30 I think). The Belarus tractors are a funny animal, from my experience. Good luck with your machine.
   / Belarus 2011 Hydro system uses engine oil ? #5
My Gravely specifies (and is what I used when I changed it) use of 10w30 motor oil for the transmission.
Ralph
Thank you very much for your replies.
Yes I have the original manual. I also understood that
they were designed for hard work in remote areas,with
little support.
Ourfarm
   / Belarus 2011 Hydro system uses engine oil ? #7
I have a Belarus 570 and always used Hydraulic fluid without any problems. Discussed with some Aeronautical engineering folks before I changed and they indicated that the Hydraulic fluid had properties that were more compatible with the hydraulic system than motor oil.
Yes, The Belarus manual does recommend 30w motor oil but as some of the other folks have stated these machines are designed to be used and maintained in a severe environment with minimum tools and without duplication of resources. My thoughts are, use whatever you want as they both appear to work well.
   / Belarus 2011 Hydro system uses engine oil ? #8
It's not uncommon for older or older design based equipment to use engine oil in the tranny and hyd's. We have some old cat equipment that takes 30w oil all around.
Soundguy
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
71052 (A49346)
71052 (A49346)
John Deere 260E DOBBS Off-Road Dump Truck (A50322)
John Deere 260E...
2018 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2018 JOHN DEERE...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
