Befco Tiller
   / Befco Tiller #1
jdeen13
PA
Kubota
I have an opportunity to pick up a new Befco tiller for a great price and was hoping to get some input on how they perform. I know very little about them and was looking at both the T30 and T40 models. I will putting it behind a B7510 Kubota. Thanks in advance.
   / Befco Tiller #2
What size tiller are you looking at?
A couple of things.... When purchasing you want a slip clutch not shear pins on the PTO shaft. Also Gear drive is generally thought to be stronger/better than chain drive. 6 tines per hub rather than 4 . The pros and cons of reverse tine tillers can be argued forever.. but generally I'm told a forward tine tiller is better for mixing in soil ammendments but a reverse tine tiller will give you excellent soil preperation in less passes.
What is the offer you are getting?
Regards,
Chris
   / Befco Tiller
I am looking at a 50" tiller that is chain driven and has 4 tines per flange. It is a forward rotation model. I don't know anything about the Befco models, except for what I have read. Thank you.
   / Befco Tiller #4
I own a few befco implements IMHO they make a great product.I own a york rake,3 pt, post hole digger and spreader.If the tiller is in good condition BUY IT.coobie
   / Befco Tiller #5
Jdeen,
I don't own any Befco implements but I have looked at them while shopping around. I can say that all the implements I have looked at from them look to be very well made. So if the deal looks good I would not hesitate to buy a Befco implement.
Regards,
Chris
   / Befco Tiller #6
Like cmhyland said, 6 tines per flange is preferred as well as a slip clutch driveline. A larger tine bar is more durable and longer lasting that the tiny ones found on some tillers. We offer a couple models of Phoenix tillers that work great with small compact tractors like yours. The T-4 48" value model or the T5-48" tiller will fit your tractor best. The King Kutter 48" XB gear driven tiller is also designed specifically for tractors like yours. Like the Phoenix tillers, all King Kutter tillers feature a slip clutch and 6 tines per flange. All of our tillers ship free to a business or supporting freight terminal within 1,000 miles of Newton, NC.
   / Befco Tiller #7
We have used a Rotomec (same as Befco) tiller here on our daylilly operation for 6 years without any issues. Very durable and does a great job behind my mom's Kubota B3030. In ours the chain is just greased and after MANY hours we haven't had any issues with the chain at all. Befco makes good equipment. Our is 42 inches and we offset it to take out one tire tread and thats good enough. I"ve got a Kuhn that takes out both treads on my Kubota L5040 and it replaceed a offset JD 660. Really no advantage to having the tiller take out both tire tracks in my real world experiance. Don't get more tiller than you tractor can handle. Everyone says get a wide tiller that takes out both tracks and you can till with low HP tractors. I disagree. If your tilling deep, and my Kuhn tills 9+ inches deep, you'll be using LOTS of power even in loam soil. If you get a more narrow tiller and offset it to take out one tire that will still leave you a very smooth garden just with ONE tractor track down the middle at the end of tilling it. Big deal. I've found it much better to balance you tiller to your tractor to cause less strain on your tractor. For your sized tractor I would get either the 30 or the 40 series and get 42 inches and offset it to take out one tire. You'll love that combo.
   / Befco Tiller #8
If it were me, I would purchase the T30-250...........although the T30-242 would works also.
   / Befco Tiller #9
I have an old BEFCO 48" tiller that even after being well used by two previous owners it still works great...very quiet and smooth...it came with a slip clutch...it's a digger...!
   / Befco Tiller
Thanks for all the advice and suggestions. After talking with Befco, I had my buddy order me a T30-250 to try.
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
Case 830 Tractor (A50514)
Case 830 Tractor...
2019 HINO 268 26FT BOX TRUCK (A52141)
2019 HINO 268 26FT...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
6 Trench attachment (A50322)
6 Trench...
