Beef Jerky Recipe...?
   / Beef Jerky Recipe...? #1
hunterridgefarm
Veteran Member
Western NC
Kubota L3130DT, Kubota L185DT, JD LX277
I have bought some great homemade beef jerky in the past but no one would give up the recipe.
Some guys at work made some out of deer meat and claimed the recipe was one someone was going to market. I was not impressed. He did give me the recipe and I am going to try and doctor it up.
We bought a dehydrator and now I need a good recipe. And thats where you guys and gals come in. I told my wife if there was a goood recipe out there someone on TBN would have it!!:D
Need mild and hot.
So anyone have a great beef jerky recipe????
   / Beef Jerky Recipe...? #2
Were you thinking of using ground beef (deer), or were you going to slice a roast. I have one of those jerky shooters that uses ground meat to make jerky. Does a pretty good job, I don't have any left over if that means it was good. Also have used roasts from a deer and had pretty good luck with that. I mainly used those packaged mixes for jerky, found them at Gander Mountain or Cabelas, even the local supermarket, High Mountian Jerky seasonings I think. Hickory and Teriyaki are my favorites. I doctor the mixes up each time that I do it and turns out a little different each time. If you are going to use roasts and slice them, I have better luck slicing them when they are partially frozen to get better slices. I think you can buy just the cure somewhere, try looking up Con Yeager Spice company.
   / Beef Jerky Recipe...? #3
I always soak it in terriaki sauce, the sprinkle some white peper and garlic salt on it. Then I put it in the oven at 250 degrees for about 4 hours. I'll check it at 2 hours to see how it's going since I prefer it a little on the moist side.
Works with beef, deer, elk or anything else.
Eddie
archerynut, I will use roasts...deer and beef. I'll see if I can find the spice company.
I would like to find a rub and marinate.
Eddie,
I started to PM you right off the bat with you and Stef shooting the boar and wild pig I knew you would have a recipe. But then I remembered I had never heard of pork-jerky:D . But I bet elk would be good.
   / Beef Jerky Recipe...? #6
I have tried a few different recipes and types of meat over the years. It is always just personal taste as to which is the best. Myself I have found round steak is easy to use and I always have lots on hand. I cut the round steak in strips removing any fat or sinew as I go. If you cut the strips at about 1/4 to 3/8,(steaks 1" thick work best) you end up with piece of meat that has some substance to it after dried. It will take longer to dry but makes a treat that will fill you up. I make a brine that has spices, liquid flavouring as well as cooked onions. My personal preference is to not use soya, terriaki sauce, or sugar of any kind. This gives you a more natural home cooked steak taste. You let the meat cure in the brine for 1-2 days in the fridge then arrange and dry in the dehydrator. Actually I think I will take some out of the freezer and start some tomorrow:)
   / Beef Jerky Recipe...? #8
Jerky is an interesting subject. It seems to get more attention than other "curing" methods ... and probably rightfully so.
Jerky is just a method to preserve meat by getting the moisture out of it via drying ... sun, dehydrator, SMOKER, or whatever. "Curing" is usually just using salt (saline solution) to pull the moisture out of meat (etc). So, same difference.
Preparing food the way you like it may be a whole different story.
What flavors do you like? What combination of flavors do you like?
I'm single. I do all my own cooking (except for the rare occasion that I pay someone else to prepare my food). I know what flavors I like.
To me, jerky is "shirt pocket food" while working. No, I don't do the trail mix, et al, thing.
Go to a civil war reenactment thing and make a point of finding the cook. He's usually really bored because nobody cares ... his gun is in his boot, not waving around where everybody can see it. His job was to keep men nourished (and secondarily nourished, in the field ... with no resources. He prepared SCRAPS of meat, along with mostly worthless hardtack (I like it too), highly seasoned with anything he had, mostly salt (if he had any left).
My recipe, if you would call it a recipe:
Meat.
Salt.
Garlic granules.
Black pepper ... the more the merrier ;)
Smoked till dry over whatever wood is available (as long as the resins don't kill you ... easy on the pine, etc.)
   / Beef Jerky Recipe...? #9
As homebrew stated, it's all in how you like it. I only use a smoker myself. Jerky, unlike a good steak, has little to no fat. Buy a cheap roast that is as lean as you can get with the grain all running in one direction. Think of sawing lumber, not cutting fire wood when slicing. Take a standard dinner plate and turn it up side down. Now you have an elivated little platform. Use a filet knife and cut from the bottom using the rim of the plate as visual guide. Cut slabs 1/4 to 3/8" thick. This will give you hand size pcs. Don't worry about some being thick and thin. Thick will go on the botten rack! Soak in a mixture of salt and sugar. Say 1/2 cup sugar to 1/4 cup salt in a qt of water. Add a bit of soy and red wine to taist. Adgitate ever few hours or when you have a chance. let soak over night. Remove and pat dry with a paper towl. Dust both sides with black peper, onion powder, garlic powder, red chili (if you like things hot). Place in a low temp smoker with hickory. Takes about 8-12 hrs. You may start pulling the thin ones off a bit sooner.
To me the key in the smoker. Check the wattage. Some come with true cooking sized elements and are to fast, say 1hour! I have modified our smoker to allow for two differnt elements. One for smoking and cooking ribs and turkeys and the low watt job for pure smoking. Add the wood for smoking just twice or it will taist like the inside of a wood stove!
   / Beef Jerky Recipe...? #10
Im going to have to try some of these recipies. I do mine with round steak if I dont have deer. on the smoker outside. like misq but have alot of oak so? I cut in strips little finger size mix up in one of those pizza shakers 1/3 salt 1/3 pepper and 1/3 garlic powder (not garlic salt) cover the meat real good and mix. put it in the fridge for the night and in the morning put it on the smoker on the cool side at about 100-150 deg. when the moisture shows on the top. turn it. you may have to do this 4-5 times. about 4 hours. dont tell anyne your doing it though if you plan on haveing any for yourself?? If you dont use the smoker I guess you could add some liq smoke and do it in your dhyd. jb
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
1964 Mercedes (A51694)
2007 Nissan Armada Multipurpose Vehicle (MPV) (A51694)
2007 Nissan Armada...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
