Bed shaper Rain Flo 2470 Mini Layer
   / Bed shaper Rain Flo 2470 Mini Layer #1
thonyc1968
kubota L4701
I have a Kubota L4701
Engine (gross): 47.3 hp [35.3 kW] - Engine (net): 44.8 hp [33.4 kW]
My soil is clay and I do not use a rototiller. My tillage sequence: plow, disc, finally I go over with the perfecta.
The specs of this bed shaper indicate that it Requires Minimum 40 HP w/ 4-Wheel Drive Tractor. Supposedly I can check those boxes. Though I'm afraid that in reality things are different.
Do you guys have any comment and suggestions?
   / Bed shaper Rain Flo 2470 Mini Layer #2
Welcome to the forum! :welcome:
Where are you? What are you planting? It's too late for strawberries. :licking:
The fact you could be dragging a lot of dirt is one reason for 40hp. Depends on how you have your bed set up. I would think your "tillage sequence" is enough if it breaks up the clay. The only way to know for sure is to try it out.
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
